RR RACING ROTOR REMOVAL(pls help)
Old Mar 17, 2024 | 12:11 PM
Dontewin's Avatar
Dontewin
6th Gear
Default RR RACING ROTOR REMOVAL(pls help)
My front rotors are rust welded and the RR Racing 2 piece rotors do not have a slot for the M8 1.25 bolt. Is there any way to take this rotor off? Or do I need to WD40 and hammer it off is what I'm thinking...
Old Mar 17, 2024 | 04:27 PM
JDMV8's Avatar
JDMV8
I've used a freakin 16 lb sledgehammer before, but I was trashing the rotor after, though it didn't seem to warp it. You could also use a slide hammer (used to remove hubs). I have a cheap 5 lb one that works great.
Old Mar 17, 2024 | 04:34 PM
Gerf's Avatar
Gerf
A good sized dead blow hammer swung two handed with extreme prejudice on the face of the rotor usually will do the trick.
Old Mar 17, 2024 | 07:36 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Expect your hubs to die in a couple of thousand miles after beating the rotors with any hammer. It's pretty common. Try heating with a heat gun or torch to loosen them up before hitting them. You might get them off without any issues with heat.
Old Mar 18, 2024 | 06:20 AM
Rickna's Avatar
Rickna
On a different car I had success with removing the wheel and stacking wood underneath the rotor. Slowly lowering the car to break the adhesion between the parts.
Old Mar 18, 2024 | 04:26 PM
Dontewin's Avatar
Dontewin
6th Gear
after an hour of soaking the rotor face and centerbore in penetrating WD40 I hammered it out after 20 minutes of hammering😭 thanks guys.
gsean400
Apr 22, 2016 02:50 PM
wr332
Nov 26, 2013 05:36 AM
AZDesertGS
Wheels, Tires & Brakes Forum
Feb 3, 2006 01:55 PM
koreanpers
Suspension and Brakes
Jun 26, 2004 11:06 PM
Goods
15
Jan 27, 2003 09:35 PM
