IS C Discussion about the convertible IS C model
Isc rear bumper options
Old Jul 25, 2020 | 04:27 PM
Firevalk01's Avatar
Firevalk01
Default Isc rear bumper options
Dumb question and I'm sure it's been asked before but I don't really see an answer when searching. Are their any rear bumper options for these car? I see the front bumper can be used from the sedan, is the rear not compatible? If not, why not? I saw a widebody kit but Im not interested in that. Does the diffuser/lip add-on work? I honestly don't even have one yet. I am just exploring my options right now to see what's other. The rear just seems really plain and boring.
Old Jul 26, 2020 | 08:35 AM
TomDac's Avatar
TomDac
The only part that is interchangeable with the sedan is the hood.. Lexus was clear in their marketing of the ISC that it didn't share any body panels with the sedan except the hood. Not sure who told you that the front bumper is the same.. It's not.
Old Jul 27, 2020 | 01:20 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
While the IS C front bumper is definitely different than the sedan, that doesn't mean it's not interchangeable. You could put an IS C front bumper on an IS sedan or an IS sedan bumper on an IS C without too much trouble (it's been done both ways), as long as to use the other appropriate parts that are different (bumper brackets, brake ducts, etc.). Lexus even did so with the 2013-2015 IS C F-Sport models, which used the front bumper from the 2011-2013 IS F-Sport sedan.
While the IS C fenders are different than the IS sedan, they're not different where the headlight or bumper mounts to it, so the fitment is the same.
Jeff
Old Jan 25, 2021 | 07:42 PM
Restless1's Avatar
Restless1
10th Gear
I have an 2014 IS350C that I would like to improve the look of the rear bumper by adding a rear diffuser. I've viewed a number of images that don't match the rear bumper the I have. The rear taillights on mine look exactly like the ones found on 2013 and earlier. However, the lights shown on every image of a 2014 and later are different.
In addition, without verifying, the convertible spare tire compartment may be lower than on a sedan because of the bracing required to keep the body more rigid. The lack of a fixed top sacrifices the uni-body concept and reliability. Probably why the rear f-Sport sway bar has an offset bend in the middle. Yes, I had the F-Sport sway bar set and lowering springs installed and I would recommend it.
A custom carbon fiber rear diffuser is out of my "just because" budget.
Old Jan 26, 2021 | 03:02 AM
benmunger's Avatar
benmunger
​​​Did you install your f-sport springs on your stock struts? If so, how long have you had them in and how are your struts doing? I'm considering f sports springs myself.
Old Jan 28, 2021 | 04:35 PM
Restless1's Avatar
Restless1
10th Gear
Originally Posted by benmunger
​​​Did you install your f-sport springs on your s? If so, how long have you had them in and how are your struts doing? I'm considering f sports springs myself.
I haven't had any issues with keeping the existing struts but, I'll install some performance ones when the time comes. Installation of the F-Sport sway bar set and lowering springs was done 5 months ago. I wanted a lower stance and increase the amount of oversteer. The ride is only a little stiffer as I try to balance comfort with performance. Looking for and finding a hard time location a strut tower bar to tightened up the steering a little more. Can always fine tune the steering by increasing the pressure in the front tires. Next step in contemplating is change the wheels from 18" to 19" with Michelin Pilot Super Sports.
Old Jan 29, 2021 | 03:00 AM
benmunger's Avatar
benmunger
Thanks. I've been considering the f sport springs but wasn't sure if the stock struts could handle them.
clammbo
Jun 29, 2013 12:29 PM
dumdumgreg
Apr 17, 2006 03:57 PM
