IS C Discussion about the convertible IS C model
Manual shifting
Old Apr 17, 2018 | 07:57 PM
ryanSC300lover's Avatar
ryanSC300lover
Default Manual shifting
I live on a top of a hill so I use gear 1 and 2 in morning to go down the hill
when I reverse out of garage and put it to manual mode, the display shows “4” as in 4th gear
then I use the paddles to make it go to “1” then I start the driving
1) is something wrong with my display?
2) why does it go to 4th gear ?
3) is it in first gear but display shows 4th?
Thanks
Old Apr 18, 2018 | 12:45 PM
Cronus1995's Avatar
Cronus1995
So that's not really a manual mode. its a "sport" mode but all it does is limit the gearing. So you slide it over and is says 4. That means it will shift up to 4th gear. When you paddle down to 1st is will limit it to just first gear.
If you tap the display button on the steering wheel you'll eventually get a screen that will give you the actual gear you're in.
It's dumb. I don't know why Toyota thought this was a good idea. It's one of the things most people hope the tuning community can change.
Old Apr 18, 2018 | 12:48 PM
ryanSC300lover
Appreciate it. Didn't realize that.
So it sounds like after I put it the shifter over, I need to double tap down twice, to get it to 2, so it can hold it there. Ugh, annoying.
Old Jul 5, 2018 | 12:18 AM
GaryJG's Avatar
GaryJG
The new 8 speed transmissions use "m" manual mode and the 6 speed transmissions uses "s" sport mode. The sport mode chooses the best gear for what your foot is doing and limits the top gear to wear you set it. It is basically a gear limiter. No real need to shift. On the other hand, the 8 speed transmissiion Manual mode "m" is whatever gear it is in until you decide to change it.
Old Aug 4, 2018 | 01:43 AM
SlenderKen's Avatar
SlenderKen
I agree it is kind of annoying to do haha. It always starts in 4th gear when going to S mode and that mode basically selects the highest gear that your car will be in.
I believe you can alternatively just hit the paddle shifter down while in D to shift to the next gear down so you can be in 2nd or 3rd gear (skipping 4th). And then when you come to a complete stop, you basically go back to the automatic shifting that D typically does. Hope that helps!
Old Aug 4, 2018 | 09:37 AM
ryanSC300lover
thanks
I am starting the car in morning in S, so it shows 4th
then an I use paddle to get it to 2.
Then i I make my 2 mile drive to the highway
juncho
Nov 28, 2016 02:32 PM
gdcheng
NX - 1st Gen (2015-2021)
May 13, 2015 07:13 PM
spotxc
Mar 30, 2014 02:17 PM
pemarsh
LX - 3rd Gen (2008-2021)
25
May 19, 2008 09:16 AM
