IS C Discussion about the convertible IS C model
Can I retrofit the new LED front running lights on my 2010 ISC
Old 07-30-12, 05:14 PM
FreshAir
FreshAir's Avatar
Default Can I retrofit the new LED front running lights on my 2010 ISC
Hey Friends,
I have a 2010 ISC 250, I see the new ones have LED running lights. Can I retrofit a kit to do this, wil the actual Lexus assembly fit on my car?
Thanks, any info or direction would be appreciated. . .
Old 07-31-12, 12:19 AM
fknISC808
fknISC808's Avatar
Originally Posted by FreshAir
Hey Friends,
maybe someone who cracked their headlights open can chime in but I dont think itll work. LED Strips might be your best bet to get the look your wanting.
Old 07-31-12, 01:48 AM
T4styPh0
T4styPh0's Avatar
Hey Friends,
It should work fine. I just bought the loaded set from Sewell that comes with the ballasts and bulbs and installed on my 08. It's plug and play except for a little modding to the bumper brackets. BTW Sewell is having a sale on them now for $600 off
Old 07-31-12, 01:54 AM
ISCjonny
ISCjonny's Avatar
As far as i know. ALL the IS models use the same headlights. ISX50, ISX50C, ISF etc. Should be the same as all the people with 4door IS's doing 2012 headlight conversions.
Buy the new set of 2012 headlights and swap it. But you will loose the AFS feature (if you had it) and a relay flasher will be required.
https://www.clublexus.com/forums/is-...on-how-to.html
Old 07-31-12, 06:33 PM
FreshAir
FreshAir's Avatar
Thanks for all your help and fast response I do have AFS, so I'll rethink this.
Biglex978
ES - 5th Gen (2007-2012)
06-25-19 11:26 AM
extremador
Lighting
05-07-15 09:34 PM
rclab1
RX - 3rd Gen (2010-2015)
12-24-13 02:56 PM
melymel96
04-24-12 11:59 AM
brettno1
IS C
11-16-11 06:25 PM
Quick Reply: Can I retrofit the new LED front running lights on my 2010 ISC
