Rear Camber Arm Torque specs
Subscribe
Oct 30, 2025 | 08:04 PM
Hi, does anyone have torque specs for the rear camber arms.
I’m planning to install rear adjustable camber arms to help with rear tire wear.
Reply 0
Oct 31, 2025 | 10:57 PM
Reply 1
Nov 1, 2025 | 09:04 AM
Quote:
Thank you so much! 🙏
Reply 0
Nov 4, 2025 | 06:25 AM
I'm about to do the same job and just want to double check I'm reading this correctly. The top bolts should be torqued to 140 and 111 ft/lbs, respectively?
Reply 0
Nov 4, 2025 | 01:24 PM
Quote: I'm about to do the same job and just want to double check I'm reading this correctly. The top bolts should be torqued to 140 and 111 ft/lbs, respectively?
Correct.
Reply 0
Subscribe
