How many miles do your tires last?
How many miles did your Bridgestone Potenzas last? I’m at 10k and down to 3/32 on the inner tread. Camber definitely increases wear but still seems pretty soon considering only some spirited driving. I had been running near 35 psi, but started to get closer to lower 30’s recently before reinflated
I'm at 11600 miles and front right tire still shows 9/32 inner and outer tread. Both rear tires are slightly below 8/32.
No spirited driving on curves, mostly straight line and a few tire spins in wet / snowy weather.
I just got a service done and I'm at 3 or 4/32 on all 4 corners on the outer and inner edges. Makes me wonder if the recommended pressures are too low since my outers were equal to the inners and all 4 corners were so consistent with each other. I'm at 8500 miles and I don't even drive that aggressively (at least I don't think I do
. Since I live in a desert and the middle tread is still at like 9/32 I'm going to try to make it to the next service at around 11k before getting new tires.
I booted the Bridgestones at 7k miles for PS4S tires. I do not remember the depth, I just couldn’t deal with the terrible performance. At 41K miles, my PS4S’ are consistently replaced every 15 months or 15K miles. My car is 100% stock and I have not experienced the inner tire wear. I keep the psi at 36lbs all around and they’re rebalanced (along with an alignment ) twice a year.
I'm on the original rear tires. Front tires are mismatched due to flats at various times. I now have 21k miles and at my 20k service the tech said I should get new rear tires in between now and the next service. So they've lasted about 20k miles. I'm on Swift springs, since 3000 miles.
RF is a Bridgestone Turanza with 11k miles, LF is a Conti Extreme Contact Sport with 7k miles, and rears are the OEM Bridgestone Potenzas with 21k miles. It's never felt unsafe because I don't push the car to the limit, but I'll probably replace all 4 soon with Michelin PS4 to see what all the fuss is about.
I've got over 13k miles on my Continental Extreme Contact Sport 02's. I still have 7/32" in the front and about 5/32" or 6/32" in the rear, with slightly lower tread on the inner edge than the outer. Front tires seem to be wearing pretty evenly laterally so far.
