Radar Detector Installs
Thank you very much Pittsy. Easy enough!
Does is matter if I use blue or brown for the ground or I have to use both of them. Kinda new to this
Xislet 15" Radar Detector Hardwire Power Cord Mirror Wire Plug Tap Compatible with Escort Valentine One Uniden Beltronics with Inline Fuse Mount RJ11 - Black, Set of 3 https://a.co/d/4k8tpve
Get this:
And the V1 USB Power Adapter Kit
Bob's yer uncle.
If you find a single dongle version of the dashcam power adapter, get that because you'll never be able to power a real dashcam from that lead.
I also bought the BlendMount, but never used it. It just made the cabin claustrophobic. I currently use the V1 suction cup mount just to the left of the mirror frit.
Bob's yer uncle.
I'd be concerned with the limited rear visibility here. The device needs clear line of sight in all directions if possible. I have mine mounted under the passenger window visor.
I've been using this mirror tap kit which is plug-and-play for my Uniden R8. Plugs directly into the stock harness. This is also compatible with several other brands if they have a RJ11, USB Micro, USB Mini, USB Type B or USB Type C for power.
I tried a blend mound, but it was too bulky and a tight fit. Went back to the stock suction cup that came with the Uniden.
Amazon.com: KWRNVO Dash Cam Power Adapter 10 PIN Type B for Toyota, Lexus, Subaru Models - Rearview Mirror Compatible With 3 USB Cable : Electronics
Amazon.com: Jsvecip Radar Detector Cable, USB to RJ11 Plug Cable,for Escort Radenso XP Uniden Beltronics Cobra Whistler Radar Detector,Replacement Power Cable for Radar Detectors (RJ11-1.6ft) : Electronics
