Lexus IS 500
From what I remember when they made the RC they used a lot of the IS's structure.
I was thinking about this, how does the motor integrate with the car?
Sub frame room with oil pan, mounts etc?
Is it a plug in play with the connectors or rewiring? Do you pull codes?
A lot of the times when change SC's engine the 1j and 2js basically plug right up to the body harness.
Was there any pain in the *** areas that took extra modifications?
Yes, unless you want a four door RCF, which does not exist. I would love an IS500 in place of my IS350, as I need four doors, which is why I ended up in an IS350 in the first place instead of a GT350 (mustang that is).
Joe Z
You're better off buying a GS-F. Assuming you have a spare 3IS vehicle to do the swap for, the cost of engine + trans is $8000+ before you even get into any custom fab stuff itll require.
Not to mention the interior, better version of Mark Levinson, etc. in the GS-F, or the fact that it weighs the same as our 3IS...
Curated Content Editor
IS - 1st Gen (2001-2005)
Feb 21, 2018 03:30 PM
