OEM Filter Replacement
Old Nov 6, 2025 | 08:23 AM
kenji211's Avatar
kenji211
Default OEM Filter Replacement
I am looking to replace my OEM engine air filter with an aftermarket air filter since I am at ~15k miles.
Which brand would you recommend? I was looking at the Tom's. I would prefer a dry filter type and not oiled.
Old Nov 6, 2025 | 08:39 AM
arentz07's Avatar
arentz07
If I was sticking with the OE filter design, I would do just that, or I would go OEM (i.e., the same brand that makes the filters that bear the Lexus label).
I, on the other hand, am running an aFe Power dry filter and have been for about 9,000 miles. It's great! I will be washing it once I hit 10k miles on the filter. It's more expensive than a single-use filter, but you can supposedly reuse it indefinitely if you keep washing it. Plus, there is a slight increase in induction sound at high RPM, which is nice.
Old Nov 6, 2025 | 11:09 AM
flowrider's Avatar
flowrider
Veteran: Air Force
Personally, I use Wix Filters for all my filters. They make quality filters
Lou
Old Nov 6, 2025 | 01:37 PM
nickrace's Avatar
nickrace
I have used K & N filters for decades on my cars and bikes. They are cleanable and you just spray for K & N oil on it after it dries. They flow more air supposedly.
Old Nov 6, 2025 | 08:44 PM
cp2's Avatar
cp2
Veteran: Air Force
stay away from the oil filters by K&N. most popular options for this car is AFE dry filter or Tom's. Less restrictive than paper. never heard of wix, but if it works, then it works. I use AFE dry.
Old Nov 7, 2025 | 03:46 PM
mg1972's Avatar
mg1972
Agree Wix are good filters.
i will probably go OEM just because it makes me feel warm and fuzzy.
Old Nov 7, 2025 | 04:08 PM
InveredMP's Avatar
InveredMP
I have an AFE dry and TOMS. I love both.
Old Nov 7, 2025 | 05:22 PM
mastershibe's Avatar
mastershibe
I tried a TOM'S and to be brutally honest, I couldn't tell hardly any difference. If anything, the induction noise lowend was quieter and the topend was the slighest bit louder. No detectable change in power.
Drove around for a week with it and then put the stock one back in, I prefer how it sounds.
Old Nov 7, 2025 | 10:43 PM
AmbyBomb's Avatar
AmbyBomb
That's not surprising for a drop-in filter.
Old Nov 8, 2025 | 06:18 AM
InveredMP's Avatar
InveredMP
No drop in filter is going to do any meaningful difference. Noise is not an indication of flow, though, so the TOMS being a less restrictive filter, would let the engine breathe better regardless of any sound change.
Old Nov 10, 2025 | 07:21 AM
cp2's Avatar
cp2
Veteran: Air Force
this goes for any not paper filter. AFE, Tom's and any other brand that does not use paper will let the car breathe better.
Old Nov 10, 2025 | 07:27 AM
AmbyBomb's Avatar
AmbyBomb
Which will still result in negligible power gains.
Old Nov 12, 2025 | 06:49 AM
cp2's Avatar
cp2
Veteran: Air Force
as much as you may be right, you wouldn't want your car to breath better? interesting
Old Nov 12, 2025 | 07:10 AM
arentz07's Avatar
arentz07
I do, and that's why I'm running the aFe filter. However, I'll be honest about the power gains - barely perceptible. I think my car has felt pretty much the same, power-wise, the entire time I've had it. The tires made the most difference in acceleration. 😁
Old Nov 12, 2025 | 07:51 AM
cp2's Avatar
cp2
Veteran: Air Force
right on...I'm with you. paper filters are very restrictive and whether there's minimal hp to gained, the fact that the engine can breathe better is most likely only going to lead to positive things. I believe that's the point that those who have done this mod believes as well. same with changing out the intake pipe to cf or ti...does it provide more hp? maybe or maybe not, but if the craftsmanship of the pipe provides a smother passage for air and provides "protection" from heat, the better the air into the engine. again, may be very minimal but still positive effect...and looks good aesthetically!
