Camber
Old Nov 13, 2022 | 08:52 PM
db05's Avatar
db05
Default Camber
Does the 3rd gen IS have camber on the front and rear tires? When i look at my car from the back the rear wheels seem to be slanted slightly inwards. Ive also heard it only has it on the front, not sure which is true.
Old Nov 13, 2022 | 09:19 PM
ex00's Avatar
ex00
Yes, the IS has factory camber for both front and rear. I believe they are also adjustable from what I have read in the forums. If tire wear is a concern, you can always change out the front LCA bushings for RCF/GSF LCA bushings. They are easy to do on your car and it does make it seem a bit more stable and responsive instead of the boat response you get from stock.
dkdillan
Dec 22, 2021 01:56 PM
EffSport
Suspension and Brakes
23
Feb 13, 2015 08:41 PM
tn96dc
Oct 29, 2011 11:06 AM
ShaneC
57
Feb 12, 2009 02:40 AM
Joshwa
Oct 16, 2006 10:29 AM
