Reset Maintenance Required
Old Nov 11, 2022 | 11:07 AM
mlfraggle's Avatar
mlfraggle
10th Gear
Default Reset Maintenance Required
Hi all,
Had a search on forums couldn't locate anything
Have a '21 is300 fSport AWD going to do an oil change myself and need to reset the maintenance required please contact dealer message that comes up on the instrument panel/speedo area.
I know previous models had some kind of hold the trip button while turning ignition on but I can't seem to locate anything for this model.
Any help would be greatly appreciated 🙏
Old Nov 11, 2022 | 01:38 PM
mcomer's Avatar
mcomer
Steering wheel controls for the Driver Information Center will open the reset option.
Old Nov 12, 2022 | 08:20 AM
arentz07's Avatar
arentz07
Check page 286 of the 2021 owner's manual (I used "Select" to denote the button used to confirm menu options, the one with the dot):
After the required maintenance is performed according to the maintenance schedule, please reset the message. To reset the message, follow the procedure described below:
1 Press < or > of the meter control switch to select Settings.
2 Press ^ or v of the meter control switch, select the “Vehicle Settings” then “Scheduled Maintenance”. (To confirm setting, press Select.)
3 Select the “Yes” and press Select.
4 A message will be displayed on the multi-information display when the reset procedure has been completed.
tl;dr it is in your gauge cluster options in the Settings sub-menu.
marky2mark
May 4, 2011 12:59 PM
StylinGS300
Jul 5, 2009 03:16 PM
Memout
Mar 3, 2009 01:09 PM
stefs
Oct 9, 2006 08:15 AM
