2014 IS350 DRL not working right
Old Jun 6, 2022 | 07:36 AM
matt2gr's Avatar
matt2gr
3rd Gear
Exclamation 2014 IS350 DRL not working right
So i ran into a problem where just my tail light fuse keeps blowing. so i disconnected all the rear tail lights and license plate lights and threw a fuse in to see what hppens and still blows the fuse upon turning just the light switch for the drl. some times it blows sometimes it doesnt blow and the lights work right up until you start the car. im not entirely sure if its a ground wire fault or if its the ecu that controls it. also anyone knows where the ecu is located? ive owned the car for a year and this is the first problem i ran into, if anyone can shoot some ideas that will be appreciated
Old Jun 6, 2022 | 08:57 PM
wongnee's Avatar
wongnee
DRL is controlled by a "Computer", this sits inside the fuse box which is near the engine.
Old Jun 23, 2022 | 10:51 AM
matt2gr's Avatar
matt2gr
3rd Gear
Problem was solved, ecu is fine
Problem originated from a short to ground fault on the front end of the cars wiring harness
vert310
Nov 15, 2024 03:27 PM
levigene59
Oct 23, 2021 07:01 PM
Measured
Aug 24, 2013 09:19 PM
mdwags
RX - 1st Gen (1999-2003)
Jul 14, 2009 09:18 AM
clevercat
Aug 1, 2007 10:07 PM
