IS250 Brake Creaking
Old May 29, 2022 | 05:08 AM
stbiss's Avatar
stbiss
Default IS250 Brake Creaking
2014 IS250 - about 47k miles - recently started to get a "creak" at nearly stop speed when braking. The best example is moving up in a drive thru line and coming to a slow stop - get a creaking sound as the brake pedal is pushed. Once stopped, can press pedal and hear it more. You do not hear the creak at a normal higher speed stop like at a stop sign unless I come to 100% stop and then press a little harder on pedal. Pads and rotors were replaced a few years back with all OEM parts. I pulled the caliper slide pins out a couple of days ago and re-lubed, but I am not convinced that fixed it. After some web searching, it seems this is common, but no one seems to know the solution.
Any thoughts?
Old May 29, 2022 | 06:14 PM
swaangin's Avatar
swaangin
Honestly, seems like your brakes are working fine. My caliper seized and they were making a grinding noise even when no brakes were applied. Everyone in the Walmart parking lot was looking. My point is, don't tamper with something if it's working. Small creaking may be a sign of wear but you said you checked the pads. Maybe switch it to a different brand of pads. You're fine though
Old May 30, 2022 | 08:00 PM
wongnee's Avatar
wongnee
Maintenance is required - cleaning
Mine got the same problem with the GS350 F Sport brake set, gone after cleaning.
JP250
Aug 4, 2014 02:54 PM
8UANEW1
Sep 16, 2012 09:55 PM
isam250
Apr 20, 2007 02:53 PM
viettho
Suspension and Brakes
17
Apr 4, 2007 07:16 PM
gsrthomas
33
Apr 4, 2007 06:14 PM
