I installed the Invidia Q300 axle back on my 2017 IS200T and the left side is crooked and too close to the rear valence.
The right side sits perfect.
I've see that the 2IS owners have the opposite problem, where it sits too low.
Has anyone with a 3IS come across this issue? If so, what was the fix?
Thanks in advance!
Here's how it sits now:
Edit:
For anyone that runs into this issue, you can make the adjustment by loosening the two bolts to the pipe that needs to be adjusted. In my case, it was the driver's side exhaust that was too close to the valance.
So I undid the two bolts from the driver side axle back, in order to get it at the right height.
Now it's hanging perfect.
Fixed:
