Lowering Lexus IS300H
Old Mar 14, 2022 | 03:32 AM
Soldat79's Avatar
Soldat79
Originally Posted by kaleo211
Thank you! I live in New England, the road condition here is not that good. If the front is too low, my front bumper would have been cracked many times. sadly no, I installed it myself.
I get it, I would like the same no cracking on the front bumper.
Old Mar 14, 2022 | 04:38 AM
kaleo211's Avatar
kaleo211
sorry not able to help here. one thing I think might be important when it comes to using different springs is the spring rate. theoretically, the spring rate would affect a little on the steering (oversteer or understeer), I forgot the relation between these. but you probably can google that.
Old Mar 14, 2022 | 12:44 PM
swaangin's Avatar
swaangin
Originally Posted by Soldat79
Ok I get it, do you think the coilovers can livre at least 50 - 70 000 Miles
Got my springs installed at 30K miles, I'm at 70K, still ride good, no strut leakage
Old Mar 14, 2022 | 12:54 PM
Soldat79's Avatar
Soldat79
Do you mean coilovers? Or springs
Old Mar 14, 2022 | 01:47 PM
swaangin's Avatar
swaangin
if you're asking me, it's the RSR down springs on OEM struts
Old Mar 14, 2022 | 01:50 PM
Soldat79's Avatar
Soldat79
Yes It was for you
I found your car https://www.clublexus.com/forums/is-...uys-think.html
Old Mar 14, 2022 | 06:43 PM
swaangin's Avatar
swaangin
If you want close to stock ride with a lowered look, RSR springs are good. They've been making springs for the IS for over a decade. If you want something where you have a huge amount of configurability and probably a significantly worse ride, go with coilovers. They also cost $1K+ not including labor, not worth it for me since the springs are fine.
Old Mar 15, 2022 | 12:55 AM
Soldat79's Avatar
Soldat79
No I don't want Lol, I believe you. I think I will go with spring, it's more safe and comfort Iike we said. There is no coilovers with low strenght spring.,like RSR spring front 4,2 and rear 8,3 kg/mm
Old Mar 15, 2022 | 09:38 AM
swaangin's Avatar
swaangin
I didn't even consider the spring rate but RSR also makes a coilover system as well (which is the cheapest one from what I understand). From what I heard, when you install coilovers, the adjustments are all 4 corners are NEVER the same, there's always small differences which lead to different ride qualities. If you are experienced with coilovers, you know how the dampening and stiffness works, then go for it but I feel like those are more for a track set up rather than the street.
Old Mar 15, 2022 | 09:50 AM
Soldat79's Avatar
Soldat79
I understand, I won t go to the rave with my IS it s a hybride 220hp, no a rocket lol.
I wondering is there is a way to adjust the rear size spring like rear spring with coilovers.
Reeladdict
Aug 6, 2016 08:20 AM
Lavrishevo
Oct 12, 2015 06:19 AM
boostinsc
Nov 20, 2012 07:51 PM
Murph145
IS F (2008-2014)
15
Jul 25, 2012 03:25 PM
GKLCPA
Nov 26, 2011 08:39 PM
