Headlight issues
Old Jun 19, 2021 | 11:15 PM
dakest's Avatar
dakest
Default Headlight issues
Hello everyone! please don't flame me for what I'm about to ask, I have searched this forum for thee days for info on this.
I have a 2014 IS 250 AWD base model with the LED headlights which I have replace the module on the right side but I rather covert to HID by replacing to the standard HID headlight assembly.
My question is, are the plugs compatible or is there any modification to it?
I had a BMW 530i with HID and it was way brighter than the LEDs in my IS, In fact my LED are kind of dim plus the driver's side gets water when it rains.
If someone has done this or have any info that can help, I would be forever grateful.
Old Jun 20, 2021 | 08:48 PM
dakest's Avatar
dakest
Really? no one?
Old Jun 20, 2021 | 08:51 PM
ex00's Avatar
ex00
I think to answer your question, it might be possible. Should be the same plugs, maybe an additional harness but you will I think need to get the modules for each side? I think people have done HID > LED conversions for housings and it should be the same just reversed. There should be several posts that outlines all of this.
Old Jun 20, 2021 | 09:00 PM
dakest's Avatar
dakest
I have searched but cannot find much info.
I can get the headlight housing and the ballast, I just need to know if the plugs need to be modified or are the same.
Old Jun 21, 2021 | 07:06 AM
Sasnuke's Avatar
Sasnuke
The headlight connections for 2014-2016 are the same for LED and HID.
The difference is the number of wires...the LED connectors have a couple additional wires.
So technically if you got two complete HID headlights they would bolt and plug right in.
What I'm not sure is if the Main Body ECU would throw any codes because it's a difference headlight system installed.
And of course you'd need to cut the extra wires.
If you want to try and install two complete HID headlights I can indicate which extra wires to terminate...it really just comes down to the Body ECU and what it will do.
Worse case...it throws a "Check Headlight" message on the dash...best case, it does nothing.
Old Jun 21, 2021 | 02:45 PM
dakest's Avatar
dakest
You always have the answer to everything! really appreciate your response!
I already have a check headlight message, my Carista says it's a bad led module.
I have compared the output with other led cars and hid cars and mine suck in comparison, the light output on the road looks like halogens
Marn1
Mar 22, 2019 10:16 AM
super400
Feb 16, 2016 04:26 PM
sleets88
Nov 5, 2014 02:13 AM
anhzie
Apr 14, 2014 12:49 PM
kevo0o
May 8, 2013 08:20 AM
