How to turn on automatic high beams
Old Mar 21, 2021 | 06:56 PM
Shannbebe's Avatar
Shannbebe
10th Gear
Default How to turn on automatic high beams
Excuse my ignorance, I’m not a car person.
i have a 2020 IS 300 and when I live in a wooded area.... the high beams used to automatically come on when I was in really dark areas.. now it doesn’t do that anymore. I must have turned it off.
someone know how to turn It back on?
thanks
Old Mar 22, 2021 | 07:11 AM
Racer00J's Avatar
Racer00J
On the dashboard to the left of the steering wheel you’ll see a cluster of buttons. The first one, top row, is typically an image of a lamp with auto written under it. That should be the button for turning off/on your auto high beams.
Old Mar 22, 2021 | 07:18 AM
mcomer's Avatar
mcomer
When the low beams are on (either manually or set to Automatic in the dark) you will see the Green Lantern Icon.
When you traditionally select the High Beams by pushing the stalk away you will see the Blue High Beam Icon.
When you select the dash button Racer00J referred to you should see a second Green High Beam Auto Icon.
Some Lexi AHB systems need both the dash button pressed AND the turn signal stalk pressed away, some only need the button press.
Note: Auto High Beam (and BSM) have a 15 MPH threshold, below that speed the High Beams and BSM warnings go off.
user 720822
GX - 1st Gen (2003-2009)
Mar 24, 2021 09:44 AM
Hameed
Jan 16, 2016 11:44 AM
johnnybmw1
Apr 8, 2010 12:13 AM
-mb-
RX - 1st Gen (1999-2003)
Dec 14, 2006 01:27 PM
lexus4jess
GS - 1st Gen (1993-1997)
Feb 9, 2004 07:28 PM
