Best square tire setup
Old Jan 7, 2021 | 09:15 PM
mrjeff51's Avatar
mrjeff51
Default Best square tire setup
What's the best square setup with a larger sidewall than OEM on a non-fpsort AWD is300 with stock suspension?
I played with some tire size calculators and got 255/40/18 as the best square setup hypothetically.
This gives a 0.5inch sidewall over stock and doesn't throw off the speedometer as much as other setups with bigger sidewalls.
I'll probably have to get new wheels: 8x8.5 all around.
Will the wider wheel look weird on the front? I'm hoping not to change the offset or use spacers if I can avoid it to make it easier to rotate the tires.
BadDog240Z
RC - 1st Gen (2015-present)
19
Jan 13, 2021 06:05 PM
eddie420
Aug 20, 2019 05:47 PM
Wandl
Wheels, Tires & Brakes Forum
Jan 29, 2015 02:07 PM
lexrod6
Sep 25, 2013 02:50 PM
robertrios
Mar 22, 2012 07:25 PM
