IS300 F Sport 2018 Overheating Problem
Old Sep 19, 2021 | 04:55 PM
  #61
Johnny916's Avatar
Johnny916
Pressure held for 3 mins @ 20 PSI, what now?
Old Sep 20, 2021 | 05:05 AM
  #62
Sasnuke's Avatar
Sasnuke
Well, aside from the block thermostat, everything you've checked would suggest the cooling system is fine and the vehicle should not be overheating.
Just to recap:
  • There is flow observed when the main thermostat is removed...this confirms the mechanical waterpump is working
  • There is also heat in the cabin with the main thermostat removed...this confirms there is no blockage between the engine and heater core
  • The main thermostat was put in hot water and opened at 82C...it is also a new OEM cap
  • The rad fans both come on and the speed varies...confirming the ECU sees that the engine is heating up and turning the fans on...although one fan wasn't working previously and now is
  • No external leaks
  • Pressure test held for 3 min...so no internal leaks (while this is a good sign, it doesn't rule out a head gasket/internal engine issue completely)
Last things to check before replacing the block thermostat:
  • compression test...this will confirm the engine is ok internally (if good, added to the pressure test, the engine should be fine)
  • hose routing...as there is a known good 200t available, confirm all coolant hoses are routed the same
  • check for codes...just in case there is a code that my give any clue as to why it's overheating...the check engine light doesn't necessary need to be on, it could be stored in History
If the three checks are good, then replace the block thermostat.
When replacing the block thermostat, as you will have the system open, I would suggest flushing the coolant system with water...from a hose is fine. This will confirm there are no blockages in the rad or throughout the system.
At the very least flush the rad...it may be new, but you never know if you didn't install it.
When the car is idling warming up, is the idle normal? Meaning it's not rough or surging.
If the block thermostat fixes it I'd be very surprised...but it's the only left if everything else is good.
Old Sep 20, 2021 | 09:28 AM
  #63
Johnny916's Avatar
Johnny916
Normal idle throughout. No codes, even in history.
I’ll check the hoses again but I’ve already checked and they look good.
How do I do a compression test?
Where would I place the hose if I wanted to check the flow in the engine?
Old Sep 20, 2021 | 09:30 AM
  #64
Johnny916's Avatar
Johnny916
Why would it be so surprising if it was the block thermostat? I seen thermostats get stuck for no reason before on other vehicles I’ve had in the past.
Old Sep 20, 2021 | 09:34 AM
  #65
Johnny916's Avatar
Johnny916
Are the hoses leading to the heater core coming directly from the engine? That’s what it looks like so I’m assuming there is a blockage in the engine, regardless of the compression test.
Old Sep 20, 2021 | 10:58 AM
  #66
Sasnuke's Avatar
Sasnuke
See attached...Item number 10 on the list. Disconnect all 8 injectors when doing it.
I think the key in your statement is "on other vehicles".
I've owned 9 Toyotas all driven to over 100,000kms each, and you know how many I've changed the thermostat because it had an issue...zero. And most of those were 5-10 years old (closer to 10 in most cases) of their life before I traded them on something newer.
The 200t you're working on is 5-6 years old and probably has less than 60,000 Miles...hence my surprise if it was the thermostat.
And true, a thermostat doesn't need a reason to fail, they just go...but since you changed the main thermostat and it made no difference, I can't see the block thermostat fixing it.
And when you flush the system when you have both thermostats out, that will tell you if you have a blockage in the engine.
File Type: pdf
Old Oct 4, 2021 | 11:55 AM
  #67
Sasnuke's Avatar
Sasnuke
@Johnny916 Did you find out the issue with the IS200t? Would be nice to know what happened to it.
Old Oct 9, 2021 | 11:22 AM
  #68
Johnny916's Avatar
Johnny916
Haven't done the compression test yet, I had to work on my other cars, but I'm going to get to it this coming week, will keep you updated. Thanks.
Old Nov 13, 2021 | 06:54 AM
  #69
Sumaya's Avatar
Sumaya
Default Hi can u please update what happen for your car, please. Did u solved your issue?
Originally Posted by one975piec
I had my 2018 Lexus IS300 F Sport Turbo overheat problem. I imported the car from USA to the middle east.
The overheating started after 2 months of normal driving. The car overheated when I was driving so I had to pull out of the road, parked, let it cool down and continue driving slowly to the garage. We found out one of the cooling fans not working due to cable puled out a bit. So, we put it back and the fan worked fine. The overheating was still there so I thought of faulty water pump and thermostat due to the overheat occurred before. I replaced both thermostat and water pump (yes the water pump was leaking). After that, I bleed the system to take all air out and everything was working fine.
After around 6 weeks, I was driving for about an hour, I reached home with no problem, while the car parked and engine switched off, suddenly I heard a huge amount of water dripping, opened the hood, I saw the bottom hose of the radiator tank has pilled off, I thought because it wasn't tight enough. So, I put it back, tight it, fill the radiator with water and bleed the system to get the air our.
Guess what !!
The car is overheating again. I went to the workshop. They blamed the temperature sensor, cooler fan and the radiator. I changed them all.
BUT STILL THE CAR IS OVERHEATING but this time only when I switch the AC on. Without AC the car is not overheating.
We found out the top pipe of the radiator is hot and the pipe at the bottom was too much cold. So we blamed the thermostat.
We took the thermostat out, took the car for a test drive and it was working fine without overheating.
We placed the same new thermostat back and the overheating issue occurs again.
I don't want to drive the car without the thermostat.
The installed thermostat been tested in a hot water outside the car and it was opening smoothly.
The temperature rating written on booth thermostat (old and new) is 82 C.
The average weather temperature here in the city is 27 C in winter (now) and 42 C in summer (March to September)
Can any body give a suggestion please !!
Old Nov 26, 2021 | 01:14 PM
  #70
Johnny916's Avatar
Johnny916
I tried doing the compression test but it looks like you have to take so many parts off to get to the coil packs, I stopped, how long should the entire compression test take to do?
Old Nov 26, 2021 | 01:20 PM
  #71
Johnny916's Avatar
Johnny916
So I should be able to disconnect the fuel injection harnesses to prevent the vehicle from starting? Does anyone have a diagram of how the spark plugs come out? Does the vehicle really have to be warmed up first?
Old Nov 26, 2021 | 01:56 PM
  #72
Sasnuke's Avatar
Sasnuke
Once you have the coils and plugs out, the entire test will be less than 10 minutes...probably less than 5 if someone is helping you by cranking the engine.
Yes to the injector harnesses.
Not sure what you mean by the spark plug question.
Ideally at operating temp as all the engine metals will be expanded to provide the most accurate reading...the reading will be as high as possible.
With a cold engine the readings could be low, but at the same time they should still be relatively equally low.
Old Nov 27, 2021 | 04:50 PM
  #73
Johnny916's Avatar
Johnny916
Default Compression is good!
All cylinders were right around 150 psi. I let the car warm up for about 5 mins.
what now? The engine thermostat?
Old Nov 27, 2021 | 05:03 PM
  #74
Sasnuke's Avatar
Sasnuke
Compression should be 131 - 174PSI with no more of a 15PSI difference from lowest to highest...so it's good at 150PSI.
Engine thermostat is the only thing left.
If it fixes it I'd be surprised, but everything else checks out, so it's the only thing left.
Old Nov 27, 2021 | 06:31 PM
  #75
Johnny916's Avatar
Johnny916
Default Thermostat
Can you send or post instructions for replacing the engine thermostat? Do you think I need to remove the AC compressor? I remember seeing that.
