‘15 IS250 AWD - Inner tire wear on front wheels
Old Sep 25, 2020 | 04:35 PM
mlaman's Avatar
mlaman
Default ‘15 IS250 AWD - Inner tire wear on front wheels
Hi All,
‘15 Lexus IS 250 AWD
recently the car has been making a bit more noticeable noise when driving and slight vibration at points (mostly drive around town)
Just replaced my rear tires today (Michelin Pilot Sport A/S 3+) and thought it would fix it, but after looking closer at my front tires I notice the inner tread on both front wheels are worn (I believe wire is showing) — this feels like I should replace the front tires as well (got an alignment done and all still checked out perfect)
Sucks because the model is staggered so can’t rotate, but has this happened to anyone else? why is the tread life normal on the other parts but worn out completely on the inner? (just replaced the front tires a little over 1.5 years ago)
pictures of front tire:
Old Sep 25, 2020 | 07:15 PM
swaangin's Avatar
swaangin
Ran into the same issue. We have the same car except mine is lowered with spacers on it. People say to get the bushings and adjust the toe to 0.08.
Old Sep 25, 2020 | 07:41 PM
Jazzrock's Avatar
Jazzrock
Have you replaced the lower control arm bushings with the RC-F ones? There's tons of information if you search for it on the forum.
Old Sep 25, 2020 | 08:22 PM
NickCaesar's Avatar
NickCaesar
Originally Posted by mlaman
Hi All,
Arguably the most discussed topic on the forum. But and install the Lexus RCF-GAF front lower control arm bushings to mitigate the problem.
euphorical
Wheels, Tires & Brakes Forum
Oct 18, 2018 10:55 PM
Tcagle
May 29, 2018 04:18 PM
bcg02
Dec 28, 2011 08:57 PM
DJSirkit13
Jun 18, 2009 02:31 PM
jhong28
Aug 24, 2008 04:43 PM
