Side Mirror Adjustment
Old May 6, 2020 | 05:05 AM
ExceLALL's Avatar
ExceLALL
Default Side Mirror Adjustment
Greetings all ,
I have a current conflict where the power adjustments for tilting the side mirrors left to right perplexingly stopped working. It works when tilting the mirrors up and down though which leads me to believe the motors within the mirror assembly are still functional and perhaps it is a bad switch? I also thought of a blown fuse maybe? I wanted to announce it here first to see if anyone has been introduced to such a problem prior.
Thanks in advance!
Old May 6, 2020 | 08:44 AM
Sasnuke's Avatar
Sasnuke
Welcome to the forum!
I don't recall seeing anyone post about a similar issue.
If it's doing the same thing on both mirrors, then I would suspect the switch or the left/right circuit of the switch (internally).
The fact that up/down works would suggest all the fuses are fine...also if both mirrors only go up/down, little chance that both the left/right motors of both mirrors have failed.
Both mirrors are directly connected to the Master switch.
Enzima350F
RC F (2015-present)
Apr 20, 2018 02:44 PM
SamySalmon
Jan 12, 2018 07:25 PM
Hotrod70
Sep 7, 2015 03:10 AM
rave90
May 9, 2011 03:27 AM
gerbjones
Jan 14, 2005 08:03 PM
