Damaged Amplifier
Old Dec 19, 2019 | 02:45 PM
iomair's Avatar
iomair
Default Damaged Amplifier
Hi all,
we had rainy days in our country last week, the OEM amplifier for non ML got wet ☹️💔.
anyone has a solution to fix the problem? Except replacing the amplifier sense it’s too expensive. I have an aftermarket amplifier, does anyone know the connection diagram of the speakers or the pins of the plug? Is there anywhere I can find the power supply board only not the whole amplifier?
thank you for your help,
Old Dec 19, 2019 | 04:05 PM
E46CT's Avatar
E46CT
Did you try pulling the amp and letting it dry out. What is the underlying cause or reason water was able to get into the trunk to begin with? Why fix the amp if it can get wet again.
I would try looking for entry points of water and fixing that. then see if the amp can dry out. if it doesn't, take it to an electronics repair shop for a quote.
the other option is used on ebay
hang3xc
Mar 4, 2020 04:56 AM
iolmaster
Jan 24, 2016 03:57 PM
DIYsquirre
Jun 13, 2005 07:30 PM
jacobking
Oct 7, 2004 05:24 PM
zogan
22
Mar 20, 2003 03:26 PM
