2020 3IS Availability
Old Oct 10, 2019 | 10:08 PM
DoggieDays's Avatar
DoggieDays
Default 2020 3IS Availability
Anyone knows when the 2020 3IS will be delivered to the dealerships? 2019 stock somewhat limited, and hoping the 2020 will be available soon.
Old Oct 11, 2019 | 07:44 AM
E46CT's Avatar
E46CT
I always check Longo Lexus if I want to see new models. Largest Lexus dealer in the US (or even the world) so they usually get stuff first. They only have 2019s. 28 IS300s, and 1 IS350. A bit on the low side for a dealer as large as they are, so it shouldn't be too much longer.
Old Oct 11, 2019 | 07:52 PM
athanato's Avatar
athanato
2020 deliveries were slated for this month however there is a backlog of inventory deliveries at least in Canada and they still have the 2019's to clear out, heck last month I got a new 2018 off the lot. IS does sell like they used to... with that said 2018-2020 are basically the same car anyways so you could get a great deal off a new 2018 if you can find one or a good deal on a 2019.
Old Oct 11, 2019 | 08:31 PM
GNS's Avatar
GNS
Anybody know the difference between the 2019 and 2020? What exactly did they change?
Also, the 2019s had auto dimming side mirrors, is there any way to check to see if that is the case? How does one tell if a side mirror has auto dimming?
Old Oct 11, 2019 | 09:28 PM
KYLexusMkr's Avatar
KYLexusMkr
You can check the window sticker or test by covering the sensor on the front of the inner mirror and a light source shining into the mirror. If you get the interior mirror to dim, the exteriors will dim as well. Not sure if it’s standard, but my ‘17 has them.
Old Oct 11, 2019 | 09:33 PM
GNS's Avatar
GNS
Oh, so the rearview mirror sensor is the one which triggers and auto dims the rear AND the sides? In other words, to dim the outer mirrors, I'd have to shine the light at the rearview mirror first to trigger the electrochromic sensor, then shine a second light at the side mirror and watch to see if that one dims.
Old Oct 11, 2019 | 09:52 PM
athanato's Avatar
athanato
My 2018 IS300 AWD F Sport 2 has them as well so the 2020 should as well as there is no reason to remove them, they are likely the same part number for all three years.
Old Oct 12, 2019 | 07:21 AM
KYLexusMkr's Avatar
KYLexusMkr
All you have to do is trigger the inner rear view mirror, the outside mirrors don’t have sensors built in, they’re dependent on the inner. They just take a bit longer to dim.
Old Oct 12, 2019 | 04:10 PM
azn406's Avatar
azn406
I'm on the search but again, that damn Mark Levinson is nowhere to be found, even on 2019 models here in SoCal. Why is it so rare on IS models...
Old Oct 12, 2019 | 06:27 PM
EZZ's Avatar
EZZ
It used to be the most common feature in So-Cal 350s. I couldn't find one without it.
Old Oct 15, 2019 | 12:37 PM
azn406's Avatar
azn406
To date, I've only found 3 with it installed, but the models were not in the color combo I'm looking for. I was looking at the NX300 as well and Mark Levinson is non-existent, as is the panoramic view monitor, and triple-beam LEDs. But I search like Kentucky or random outer states and they have models with these options built in. Don't get why SoCal barely has fully-loaded models.
NIAautoDesign
Nov 29, 2017 02:02 PM
Rockstr512
Feb 11, 2015 05:59 PM
gmfeny
GS - 1st Gen (1993-1997)
May 4, 2007 01:26 PM
