Tire setup to kill understeer
I've taken corners fast in my IS200T F-Sport pretty fast, especially on the spiral offramps, and never lost traction let alone understeered. I have some offbrand tires that came with the car CPO, called Barums. For you to be continuously understeering you're definitely going too fast
I run 235/40 18 myself on stock rims square and no issues. I might rotate em with spacers 20mm and 15mm as i have gsf/rcf front bushings for inner tire wear. Hope those bushings helped, will check in a month or two. But my rears are still wearing hard on the inside, so to prolong the life of my Michelins pilot sport a/s 3 + I would have to rotate em
Also, how's the grip? Does the car feel more neutral?
But yeah, even though I understand that the IS is front heavy, especially with that chain drive transfer case thing up front for AWD, it pushes the limits of the front tires too soon while on track. BMW's xdrive is technically a similar rear biased system, but my buddy's 428i xdrive doesn't have the same tendency, even without the M sport suspension thing. Its also not a lot lighter, probably 100lbs. It can be made to rotate at corner exit with easily controllable oversteer. (Its a lot slower overall but that's not the point lol). It is however, running a 225 all round square setup. Which brings me back to tires....
My rears were wearing on the inside from the get go, haven’t checked michelins yet but 100% sure they will. Alignment is fine its the camber which is not adjustable. Unless i buy camber kit. I read this forum and some people experience it too with awd cars and my dealer said it is what it is aggressive set up from the factory bs.
Spacers is just to push ur wheels out for more aggressive look. Not needed at all but I might use it for the rotation of the wheels ( back to front) because rears won’t clear the callipers without spacers.
Tires are ok, great grip on the wet road. I keep them over inflated a bit at 39-40psi cold as paranoid about stupid inner wear so there is a slight understeer in hard corners but I feel if psi would be set lower at oem specs grip would improve.
I had swapped the front and rear on my 2014 IS 350 AWD while trying to figure out front wheel noise (this was before I knew about the soft LCA bushings).
I didn't drive it long this way, but I didn't have any issues with the wider wheels up front.
lexo101
May 11, 2017 04:30 PM
