Originally Posted by beezmarkee
(Post 10567869)
Is it profitable doing on swap in America? You have a760h transmission now, it will works super with a 2GR-FSE combo. But you will need to make some ECU tunes.
(Post 10567878)
All works well if u make right tune on ECU. No need to install ECU from 2GR-FSE: hardware remains the same.
The stock harness for the 2,5L shouldn't have connectors for ALL the injectors, unless you're only using the 6 port injectors now, and none of the direct injectors. |
(Post 10567878)
