View Poll Results: Have you experienced early inner tire wear on your 3IS?
Yes
55
77.46%
No
16
22.54%
Voters: 71. You may not vote on this poll
3IS Inner Tire Wear
Thanks for the detailed explanation E46CT.
Glad to hear switching to RC F bushings has been good for those who have done it. Anyone else have experience with RC F bushings? How many miles do the tires last? How many hours of labor does Lexus charge for changing four bushings?
lexus charges “book time” which is around 2-3 hours...
its a 30 min job from start to finish just find a good independent mechanic. Bushings don’t need to be pressed it’s an unbelievably quick easy job.
Just had my alignment done due to severe inner tire wear at 7K miles. Car was severely out of alignment. I've owner other sports cars with excellent handling w/o an inner tire wear issue...so I'm not sure that this dynamic is baked into the car in such a way as to burn thru tires so quickly. Most folks who buy sports cars tend to push them more than they would a basic sedan, so the jury is out for me on whether this design is the issue.
i'll see after 10K miles and following this alignment, fi this is a design "flaw".
this was explained to me by several master techs at various Lexus dealerships. Here’s a video showing it..
I can tell you I had HORRIBLE inner tire wear on my tires, I installed the RCF/GSF bushings, did not get an alignment, bought new tires and after 10,000km of driving and have no uneven tire wear.
Jbreezie (05-01-19)
As sure as today is Wednesday the inner tire wear is caused by lower control arm bushing movement under hard loads (dynamic toe)
https://m.youtube.com/watch?v=mpG32GK2mUY
I've said this years ago on other forums and on here. Pay close attention:
The inherent design of cars in this class and up calls for suspension design that leads to accelerated wear in general and specifically accelerated inner tire wear. The Lexus IS just happens to be tuned more towards the extreme side of this "class spectrum." In layman's terms, Lexus baked in more compliance than on other offerings within their brand portfolio, and more so than other brands.
Mercedes, BMW, Porsche, etc. all experience similar wear and all have lodged complaints on forums.
The takeaway here is that you can't eliminate it all. And you don't want to. This isn't a Corolla. You have to pay to play.
I have attached a photo on a BMW exhibiting the same characteristic. I had previous BMWs that did the same thing. BMWs tend to do it more on the rear as their rear trailing arm bushing is tuned for a ton of dynamic toe (part of BMW's secret to their famous handling). It's what has given BMW extreme stability under braking from high speeds. Remember the magazines growing up as a kid that praised BMW handling?
BMW invented this suspension philosophy. They pioneered the class. A bit of learning material for you guys from E46CT.
that’s what you want, also 1 thing to pay attention to is unless your lowered you want the “0 degree caster” ones. Shop around for best price on the parts, eBay is great, and make sure your not charged more $$$ than you should be, it’s a 30 min job don’t get ripped off.
This is a very helpful thread. I bought a 2014 IS 250 and have noticed a vibration above 65-70 mph. It is almost always there but can vary in intensity; sometimes with the road surface. Is this higher speed vibration a common symptom from inner tire wear? I look forward to inspecting my wear pattern later tonight. Thanks again for all of the good info.
I am experiencing front and rear inner wear.
For the fronts I have installed rcf bushings month ago hoping to resolve the issue but what to do with the rears? It’s 2015 is350 F AWD
