RSR Down vs Super down
Old Jan 13, 2019 | 04:25 PM
  #46
swaangin's Avatar
swaangin
Originally Posted by chinox22x
usually not recommended due to spring rates specially if the poundage is different. you may find swapping rear end (or front) on the corners if the poundage isn't right.
RSR regular down:
  • Spring Rates:
  • Front 5.48kg/mm
  • Rear 7.40kg/mm
The RSR down front and rear already have different spring rates and I just checked,
The super down front spring rate is: Front 5.10kg/mm
Would that make a difference..?
Old Jan 22, 2019 | 08:52 AM
  #47
AtomicAWD's Avatar
AtomicAWD
Originally Posted by swaangin
RSR regular down:
  • Spring Rates:
  • Front 5.48kg/mm
  • Rear 7.40kg/mm
Spring rates are all over the map, so we can't go by them only as there's many other factors in their design (length, thickness, number of coils, etc.). Only wish it were that easy!
SC215
Oct 17, 2018 04:56 PM
is250fsprt
Oct 24, 2013 11:10 PM
Johnson25
Oct 16, 2012 11:53 PM
Sango
Suspension and Brakes
13
Apr 26, 2012 07:16 PM
ocbc
Jan 28, 2009 09:28 AM
