Hey guys, got a ‘14 IS350 and have noticed in the past few days that my shifts are feeling different. Most notably going from 2nd to 3rd. Shifts are feeling kinda sluggish and at times even a little jerky. Also noticed in Sport mode, getting off quickly on 1st feels wobbly/slidey?? Bought this car in May with about 50k miles and have put almost 7-8k miles since, a good 6/10 times im driving the car a little aggressive (:<
Dealer said they changed allll fluids when i took it off the lot in May but have felt the difference in the transmission pretty notably. Looked in the engine bay for like 2 minutes before realizing it had no dipstick lol
I went to my local Lexus dealer and they refused to do it because of it being "lifetime" fluid.
Anyone had this done and know how much they paid for it?
my dealer charged me for the gasket and an hour of labor and i had my favorite master tech do it ... i did bring my own amsoil tranny fluid ... lexus charged 175$ to do it with my own fluid.
Its true what Toyota/Lexus says being lifetime fluid (100K miles).
But I'm planning on doing a drain-and-fill @ 50K miles. Not a full flush-and-fill.
For the drain-and-fill: park the car as level as possible, measure what is drained and put the same amount back.
Going to also check Diff fluid at 50K as well.
It depends how technical you want to get with it.
Leveling of parking.
Temperature of transmission.
Amount of fluid.
Type of fluid.
Torque spec for drain/fill bolts.
I think there is a full Toyota/Lexus technician procedure sheet of ther process in the ISF forums somewhere.
The only thing potentially different in this video is the amount of fluid since 3IS come in 6/8 speed transmissions.
The Aisin drain/fill bolts are pretty the same position for both trans. The Fill bolt is labeled with "WS" so you cant miss them.
Procedure will be identical to this:
