Slowly leaking tire...help
Old Sep 25, 2018 | 10:47 AM
Maxxxx's Avatar
Maxxxx
Default Slowly leaking tire...help
I have a 18’ IS 300 AWD F Sport and as the title says, my driver side rear tire is slowly leaking(loses about 3psi per day). I’ve been pumping it for a few days to see if it’s still leaking, and yes...still happening
took the tire off and checked, don’t see any big holes
could it be the valve stem causing the leak or a very tiny puncture I did not see?
The tire is pretty new, hope I don’t need to have it replaced. should I take it to the dealership and have them check it out or local tire shop will do? any thoughts and ideas will be appreciated!
Old Sep 25, 2018 | 10:49 AM
E46CT's Avatar
E46CT
Take it to the dealer. Any tire shop will do but it's a new car. Could be some material on the rim bead seat or a faulty valve stem. could be just a plain defective/damaged tire. they'll dunk test it as well. whatever it is, as long as it's not damage from an object, it'll be covered.
Old Sep 25, 2018 | 10:55 AM
Maxxxx's Avatar
Maxxxx
That makes sense...Thanks!
Don't want this to be the second tire I have to pay for in the same month lol (pothole cracked my pas. front tire sidewall not long ago)
and one more thing...should I take my spacers off before going to the dealer to avoid warranty issues? or leaving them on's okay
Old Sep 25, 2018 | 12:15 PM
E46CT's Avatar
E46CT
Just leave them on.
Old Sep 26, 2018 | 03:00 PM
skiracer's Avatar
skiracer
Any tire shop will just remove the tire off then dunk it in a tank of water to see where the air bubbles are coming from.
Old Sep 27, 2018 | 06:35 AM
Sasnuke's Avatar
Sasnuke
If you have a spray bottle, fill it with soapy water and spray the wheel down all over.
It will bubble where the tire is leaking, and you can clean the whole assembly at the same time.
Chances are it's a tiny puncture...but anything is possible.
Old Sep 27, 2018 | 09:24 AM
V350's Avatar
V350
Could also be a bent wheel, check the wheel out as well.
Yinzer
Mar 12, 2013 02:21 PM
chobreeezy
Jun 18, 2011 08:52 PM
dkny_112
Wheels, Tires & Brakes Forum
Feb 24, 2004 08:33 AM
theanimala
Dec 18, 2002 02:38 AM
theanimala
Dec 28, 2001 11:11 PM
