Best brand for touch up paint for Ultra White 083?
I know the paint has 3 layers (color, glass flakes and clear coat) but most I found only offer 2 bottles (color and clear coat). The OEM one from the dealer seems to have a slight yellow tint to it after you have it on for awhile.
FYI , lexus 083,,, come in two bottle ,one is 083 BC (this is the white base ) and the 083 ( this the metalic coat,) for some reason this is not clear, so when paint over the 083BC it turn a yellow white ,, not white anymore,, so this would never ever match the original paint color with the metalic , since it not clear with metalic
Hard to tell from that picture, but I had my front bumper replaced and when they did the paint job there’s 3 layers to it the base white and metallic flakes that gives it shine then finally clear coat. If you look real up close you should see super tiny like glitter. That’s the best way I can describe it. Shouldn’t matter if it’s metal or plastic you probably got burnt.
I recently had to order some Ultra White. Will let you know how it works out. It includes Chip and scratch putty. Brush on one end, pen on the other. 4 Pens, Primer,Basecoat ,Midcoat, Clearcoat. Also sand paper,glove, and polsh. Called Touchupdirect.com .
This is an old post I ended up getting dr.color chip and it works fine
Jazzrock (02-07-23)
DanozLS430
08-24-07 06:24 PM
jkalu47
07-11-07 02:55 AM
