Hardwiring a dash cam
Old Apr 20, 2018 | 02:44 PM
Sblexusis's Avatar
Sblexusis
Default Hardwiring a dash cam
Has anyone successfully hardwired a dash cam. I have the kit but I want to make sure I hit the right fuses bothe accessory and constant battery.
Anyone?
Thank you!
Old Apr 20, 2018 | 03:10 PM
E46CT's Avatar
E46CT
Yup very easy. Just need a power and ground. Use multimeter to confirm. I used wires located in the harness above the sunroof switch panel. Switched 12V and ground. Use a wire tap so it's clean.
Lay out the wiring on a table and visualize what you need to do, how much wire you can trim/cut off, etc. Very small space, won't need much wire.
Old Apr 20, 2018 | 09:21 PM
minhael's Avatar
minhael
Here's my fuse tap for both accessory and constant power for parking mode.
Old Apr 21, 2018 | 07:38 AM
Sblexusis's Avatar
Sblexusis
What do you think about his set up? He didn’t use piggybacks but just stick the wire in the fuse slot and connected the existing fuse.
Old Apr 21, 2018 | 07:52 AM
minhael's Avatar
minhael
It's best to use a piggyback but the issue with the piggyback is that the fuse cover can't be place back in.
chunkyda
Jul 17, 2020 04:27 PM
justYnG
IS - 1st Gen (2001-2005)
Feb 17, 2017 06:06 PM
needslipo
Dec 21, 2016 01:48 PM
philwojo
NX - 1st Gen (2015-2021)
Mar 10, 2015 09:04 AM
tfischer
Apr 7, 2006 11:54 AM
