Cluster Lens Replacement advice
Old Apr 20, 2018 | 02:01 PM
RageRacerM's Avatar
RageRacerM
Default Cluster Lens Replacement advice
So, I’m changing out the lens either tonight or tomorrow, and jus wanted to confirm a few things. After removing the two screws at the bottom of the panel, i tilt down the panel? Then i remove the plastic cluster lens housing by literally just pulling it off while being cautious of the ignition start/stop attachments? Then just detach the original lens. I’ve seen the youtube clips by beatsonic that indirectly covers this. Just want to be sure Im not missing a step.
Mainly, I just want to be sure as to not introduce dust, dirt, or oil inside the new cluster lens or the tachometer etc. To reduce risk, ill wear gloves. Was thinking about using compressed air to blow away some of the debris before detaching the old unit, but not sure if I’d want stuff floating in the air.
Thanks for those who chime in. Happy Friday.
Old Apr 20, 2018 | 03:20 PM
E46CT's Avatar
E46CT
how did you manage to ruin your cluster lens? You usually see those last 20+ years.
Old Apr 20, 2018 | 03:24 PM
RageRacerM's Avatar
RageRacerM
Nothing I did. It was the previous owner. I just picked this up CPO in October :/
Old Apr 20, 2018 | 03:32 PM
RageRacerM's Avatar
RageRacerM
Just to add, there’s one gigantic scratch running down the center right in front of the tach, with a bunch of mini micro scratches all throughout
E46CT's Avatar
E46CT
Maybe they used some harsh chemicals on it? Or is it scratched? Make sure you show a before and after!
Old Apr 20, 2018 | 03:34 PM
E46CT's Avatar
E46CT
Ahh may be difficult to find advice as there's probably not many who've done this repair. but doing other clusters, usually yeah you just unscrew it and it tilts down. Just make sure you get all the dust out as one speck of dust will bother you forever
Old Apr 20, 2018 | 04:23 PM
EZZ's Avatar
EZZ
The lens cluster is super soft. I had mine replaced as it was all scratched up from the dealer cleaning the interior of the car
lbcgav
Jan 19, 2019 07:28 PM
spoogenet
Nov 30, 2016 09:19 PM
rcan1015
Oct 25, 2014 02:26 PM
HotBoy
Jan 3, 2004 10:32 PM
spinedoc
Oct 18, 2001 08:08 AM
