Steering Issue Finally Resolved - LONG, LONG POST
Old Jun 25, 2022 | 06:29 AM
  #46
RA050224's Avatar
RA050224
2022 IS300 AWD. I will occasionally feel a little non-smooth feeling in the steering wheel, but it's nothing alarming. Can't call it notch even. Just a microsecond of less smooth transition. Never anything even remotely dangerous (so far). AND, I swear if I do feel it, it is when I've adjusted the electronic steering wheel tilt or telescope function.
Old Jun 25, 2022 | 12:30 PM
  #47
arentz07's Avatar
arentz07
Interesting. I haven't experienced it since I visited the dealership and the tech had moved the steering wheel. There must be some relationship.
Old Nov 18, 2022 | 09:53 AM
  #48
PrimeDave's Avatar
PrimeDave
I wonder what the sweet spot is? Steering wheel tilt to a certain driveable usable position for the driver. Then poof! The notchy issue goes away?!
P.S. I have also noticed this same issue, very very minor though, on my 19 IS.. Not nearly as severe as some have described with theirs on this thread.
Old Nov 18, 2022 | 10:03 AM
  #49
arentz07's Avatar
arentz07
For whatever it's worth, ever since I switched to Milchelin Pilot Sport 4S tires and got an alignment, I've had zero issue with the steering. Before that, I was intermittently seeing the issue even at lower speeds. I wonder if, for me, it was alignment-dependent.
Old Dec 19, 2022 | 12:36 PM
  #50
Daniyal's Avatar
Daniyal
10th Gear
Originally Posted by kj07xk
Guess I'll jump in here too, 2014 IS 350 AWD, with the same symptoms. Long straight stretch of highway, usually doing 80+ MPH, when highway takes a slight bend, the car doesn't want to turn. Takes more than the normal fingertip pressure to get the steering wheel to budge, definitely a 'stuck in a notch' feeling.
Once 'freed', it doesn't reoccur for awhile. Maybe happens 1-2 times per 2 hour highway drive. After the first occurrence, I find myself giving the wheel a periodic jiggle, just to see if it is still free. Then I forget about it until I find it 'stuck' again.
Often wonder if its a 'heat transfer' thing. The heat from the engine and wheels is transferring to some other component, maybe the steering rack, and causing lubrication to flow out of some area, causing it to 'stick' when movement is attempted. Once it does move, that area again gets lubricated, and so it doesn't stick again, until allowed to be motionless on another long straight stretch.
Symptom doesn't occur in city driving, as more turns occur, keeping that 'thing' lubricated.
Might be interesting to sit with the car in 'P', run the engine at 2-2.5K RPM for 15-20 minutes, and then see if the steering wheel feels 'stuck', just to see if engine heat affects it.
If not, putting the car on a lift, and do the same thing in 'D', although the suspension components are now unweighted, unlike real world driving.
The first time this occurred, was more than a bit unnerving.
I don't recall this happening before I installed the FIGS LCAs, but I also now drive faster since installing them, as fast deceleration on the OEM LCAs was just scary, as the car was squirrelly and wanted to wander all over when braking from 90 to 60, when some idiot pulls out in front of you.
Im currently having this issue, went to 3 dealers multiple times and they all say nothings wrong. I’ve got the RCF/GSF bushings.
Someone please help, just need the steering to be smooth and a pleasant driving experience before I decide to get rid of this thing.
Old Dec 19, 2022 | 01:53 PM
  #51
s3v3n's Avatar
s3v3n
The last words you said is the only solution
Old Dec 19, 2022 | 02:17 PM
  #52
Daniyal's Avatar
Daniyal
10th Gear
Gotta be a solution, even if expensive. I’m just trying to pin point the issue to fix it.
Old Jan 9, 2023 | 02:38 PM
  #53
adict2rice's Avatar
adict2rice
mine keeps pulling to the right even after 4 wheel alighment! low speed and high speed.
2015 GS rwd f sport no mod. 63k miles
Old Jan 10, 2023 | 06:17 AM
  #54
PrimeDave's Avatar
PrimeDave
It just hit me.... Is it possible that this steering notchy feeling described throughout the thread is because of the LCA bushings being switched out to RCF/GSF, or Fig, or RR lca bushings? Could that indeed be why this is happening? Considering how the lca bushings being switched out, now helps the car handle better and decelerate/brake without getting all squirley, and keeps the car strait... Well is it possible its causing this steering notchy feeling when on long highway swooping turns to the left or right?
Old Jan 10, 2023 | 06:24 AM
  #55
arentz07's Avatar
arentz07
Possible for some, but I still haven't upgraded the bushings and have observed the issue.
Old Jan 10, 2023 | 07:03 AM
  #56
PrimeDave's Avatar
PrimeDave
That was my next question... Lol. Welp, I guess we are back to square one...
Old Jan 10, 2023 | 08:50 AM
  #57
Daniyal's Avatar
Daniyal
10th Gear
That was my exact thought but I haven’t switched back from the RCF bushings yet. Anyone willing to try and check?
Old Jan 17, 2023 | 10:59 AM
  #58
Osmann's Avatar
Osmann
Originally Posted by spineman
Well, this issue has been happening to me starting this year in 13 GS 450h. It first started when really cold outside. Then the "catching" as ya'll describe above. Most recently I starting getting a scraping sound at steering wheel. I figured it was the clock spring or SRS reel as many people have posted. Finally took it to Lexus and...of course....it needs a new steering rack. $2500 installed. Ouch! I asked if they could rebuild it and of course they can only replace. Still awaiting the part and driving a ES 300h loaner. That car makes me miss the GS big time.
did you get a new steering rack, and if so, what are the changes it made for you?
Old Mar 14, 2023 | 12:01 PM
  #59
marjenmill's Avatar
marjenmill
Yeah, I have the same issue with my 2015 GS350 RWD, no LKA. It's a serious problem that Lexus does not want to admit.
Report your issues to NHTSA at: File a NHTSA Complaint
Old Mar 20, 2023 | 08:10 PM
  #60
low3is's Avatar
low3is
1st Gear
Default Having this issue with my ‘19 IS300
I’m having the same issue on my 26k mile IS300.
This only happens on the highway going in a mostly straight line for a long duration of time, typically kicks in around 20-40 mins. It gets sticky/notchy trying to get to the center point going straight and is very hard to get it to move to make minor corrections. If i hit dead stop traffic for let’s say 10 minutes and then get moving again, it disappears until I hit that 20-40 minute mark again, no matter the speed. Any ideas? I’ve seen some people mention the power steering gear rack.
