View Poll Results: Which MICHELIN tires do you like best for an IS350 FSport RWD?
MICHELIN PILOT SPORT A/S 3+
56.60%
MICHELIN PILOT SPORT PS2 ZP
5.66%
MICHELIN PILOT SUPER SPORT
37.74%
Voters: 53. You may not vote on this poll
Help Getting New Tires ?!
Old Mar 13, 2019 | 07:10 AM
  #46
ZISF's Avatar
ZISF
I've done a fair share of research and went with the Michelin Pilot Sport A/S 3+. Worst decision ever. They hummmmm, at weird speeds. I've had the fronts replaced under warranty and it reduced the "hum" but its still evident.
Old Mar 13, 2019 | 09:31 AM
  #47
Flash5's Avatar
Flash5
I have the hum at 70 MPH but it doesn’t bother me d:
Old Mar 13, 2019 | 12:12 PM
  #48
LaZeR's Avatar
LaZeR
Question
Hey @Flash5 ~ and peeps with Michelin Pilot Sport A/S 3+ ~ how many miles are you at, and how's the durability, longevity, treadwear, etc? Thanks!!
Old Mar 13, 2019 | 12:41 PM
  #49
Flash5's Avatar
Flash5
I’ve only put like 4,000 miles on them so far. They work just as well as they did on my G37S. They are a really good A/S tire. They do hum at 70 mph but I’m used to noises so it doesn’t bug me.
Old Mar 13, 2019 | 02:15 PM
  #50
arentz07's Avatar
arentz07
I wonder if that hum will go away as the tires wear. My BFG's had a similar hum for a couple thousand miles, but the last several times I drove on the interstate I didn't hear a thing.
Old Mar 13, 2019 | 11:59 PM
  #51
Flash5's Avatar
Flash5
Either, Germany has different air/wind or the tire wear is making it less noticeable because over here the hum isn't as loud or constant as it was in the states. I noticed it when I received the car from the shipping company so might be the former lol.
Old Mar 14, 2019 | 03:05 AM
  #52
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
It could be from wear or lowering.
Old Mar 14, 2019 | 03:07 AM
  #53
Flash5's Avatar
Flash5
Car was already lowered and as I stated, I noticed it as soon as I picked up the car from the shipping company so no additional miles were put on the tires. So it's most likely the weather here, etc.
Old Mar 14, 2019 | 04:54 AM
  #54
twixx007's Avatar
twixx007
I have these tires as well and don't have any issues at all here in Germany too. I've even gotten my car up to 158 MPH on the Autobahn with no issues.
Old Mar 23, 2019 | 09:28 PM
  #55
LaZeR's Avatar
LaZeR
Arrow
Hot Dang ~ for the very first time in almost 2 years, Michelin Pilot Sport A/S 3+ is LEADING in the Polls at ~49% versus 2nd place Michelin Pilot Super Sport @ ~44%.
Old Mar 24, 2019 | 08:02 AM
  #56
TOPENDMS's Avatar
TOPENDMS
Former Sponsor
A long time ago I had Khumo tires on my Honda Accord and the side walls constantly got damaged from road imperfections causing bulges that required them to be replaced immediately and was not covered under warranty. I would never use cheap low profile tires again.
Old Mar 24, 2019 | 11:50 AM
  #57
LaZeR's Avatar
LaZeR
Question
I thought the ONLY choice to fit IS350 FSport are low profile tires.
Are you able to fit NON-low profile tires on IS350 FSport?
Or, are you just saying that Khumo tires specifically are cheap?
Old Mar 25, 2019 | 11:43 AM
  #58
Pittsy's Avatar
Pittsy
Originally Posted by EZZ
Then the A/S 3 are the way to go. I have the Super Sports and it feels like the hand of God guides my car through corners...grip is soooo good with those tires. However, you will definitely have less tire life for sure (~20k)
Not only this but PSS's get super dangerous below like 40 degrees F. The compound becomes stiffer and changes and the rear end will kick out in turns during cold temps, you can only imagine what would happen if the roads were icy or snowy or wet.
Old Mar 25, 2019 | 12:50 PM
  #59
Flash5's Avatar
Flash5
Any summer tire shouldn’t be used at those temps. Not only are they dangerous, you will very likely destroy them at those temps. They are called summer tires for a reason.
Old Oct 22, 2019 | 11:19 AM
  #60
ISTreeFidi's Avatar
ISTreeFidi
Honestly I wouldn't recommend Michelin for the IS. I have the Pilot Sport A/S 3+ on mine currently. The performance is great, wet or dry, I can take off from a red light super quick and corner confidently. It performs admirably in snow also, no problem there. However after 8k miles, the front tires has developed some serious uneven wear on the inside and no longer ride smoothly at certain speeds. Front tire wear is a known issue for the IS with any tire, but according to my dealer, Michelins in particular does not play with IS well, they've had other people with Michelin come in with the same issues I had. It's not all IS mind you, but some owners had this problem. It still performs well and is miles ahead of the stock tire, but the minor issue is a bit annoying. I will probably seek out alternatives with the next set.
