Nav Screen Scratches
I've been using a cleaner called Plexus to clean mine without any issues. It's designed for cleaning lexan, plexiglass and other plastics, but it's a gentle cleaner and works well when used with a soft terry cloth.
I got it from Amazon. I originally got it for cleaning the plastic windshields on motorcycles. It worked great for that so now I use it for everything that's delicate.
http://www.lexuspartsnow.com/parts/lexus-parts-multi-display~86134-53030.html?Make=Lexus&Model=IS350&Year=2014&Submodel=Base&Filter=()&Location=navigation-front-monitor-display,,86134A
Is there even a way to clean the nav screen without scratching the anti glare coating?? I've had the Anti Glare coating replaced on my IS a while ago. Well I decided to clean it today, because one of my friends touched it the other day thinking it was a touch screen. I used a lens cleaning cloth and guess what!! It's scratched again!!! It's so annoying that this thing gets scratched even with so much care.
ALL plastics are prone to scratches to a degree. One just has to understand why what the cause of scratching. If you use a very soft microfiber of some sort along with good lubrication (cleaner) theoretically it should not scratch right? but it still scratches... that's because there are fine solid partials of dust/sand that are stuck on the screen either from oil/moisture contents in the air or static. The key to cleaning screens or any soft interior plastics are to remove as much of these solids as possible before you make any physical contacts to them with a cleaning cloth... compressed air with vacuum is a very effective way of doing so.
Just imagine, you wouldn't just wet a car wash towel and wipe your car body clean would you? no, you soak and wash away all the larger dirt particles first with pre-soak, and rinse first right? same idea
Once you got the screen cleaned, consider a screen protector film just like people do with cell phones, if that gets scratched, just replace the film for a few dollars instead of a screen that's wroth hundreds if not thousands
fetalsono
Jan 12, 2003 11:03 AM
