Sport+ Suspension
Old 07-13-16, 09:37 AM
SceneAmati
SceneAmati's Avatar
Default Sport+ Suspension
This might be an odd question, but is it possible to make the Sport+ suspension mode permanent in all modes?
Reason I ask is because I recently lowered my car with RS*R Down Springs, and I feel that in 'Normal', it feels a little bouncy and when I switch into Sport+, it feels stiff and it feels more confident when driving. Might just be roads I am going on but I like the stiffness of Sport+.
I'd like to keep that stiffness of Sport+ without sacrificing the gas mileage. Is that even possible?
Probably not, but worth asking you all. lol
Old 07-13-16, 11:06 AM
MasonGrey
MasonGrey's Avatar
This is all hypothetical, but it should be possible. Switching to S+ simply changes the dampers so if you removed the module on top of the struts, you should be able to manually adjust the **** until it where Sport+ should be.
As I said, this is all hypothetical, but I think this is how it would be performed if possible.
Old 07-13-16, 11:27 AM
SceneAmati
SceneAmati's Avatar
Definitely makes sense! I wonder if anyone else has thought of this or at least tried it? Hmm...
Old 07-13-16, 02:22 PM
MiKeLoBe
MiKeLoBe's Avatar
I've been thinking the same thing too. Try it and let me know if it work.
Old 07-15-16, 10:05 AM
EJ255t
EJ255t's Avatar
i had RSR downs and on normal mode it felt a little soft, but sport mode its not as bad, Sport + is where you feel the difference.
Im now on RSR half downs and its a pretty noticeable difference when you're crusing on normal and sport +.
Also on the OE springs, normal will feel really soft and bouncy, Sport +it will stiffen and steering will tighten up. half downs/down springs will enhance that and make your drive feel more sporty.
Hope this helps
Old 07-18-16, 09:40 AM
SceneAmati
SceneAmati's Avatar
So you're saying the halfdowns are stiffer?
I really don't want to have to swap out springs again. Also I like the look of Downs. I just wish there was a way to hack the AVS so that it can be manually adjusted and keep the stiffness of Sport+ in normal mode or all the modes.
Old 07-18-16, 03:19 PM
EJ255t
EJ255t's Avatar
halfdowns are stiffer then OEM springs but are softer then the Down springs.
they both ride very nice, only reason i went to Half downs was so i could fit wider tires on my wheels.
Nail34
RX - 4th Gen (2016-2022)
21
04-12-18 09:05 AM
jucytec
01-06-15 09:49 PM
zoolster
Suspension and Brakes
12-11-14 12:08 PM
astrotoy
03-28-09 01:48 PM
Quick Reply: Sport+ Suspension
