Wheels and Speedometer/Odometer?
I just upgraded to the 3IS F-Sport wheels from the base 17" non-F wheels. Would I need to bring my vehicle in for calibration for accurate reading or would it not matter?
and compare the tire size. I think below 3% is acceptable (not sure)!
Try this : https://tiresize.com/calculator/
I wouldn't worry about it too much if I were you. What's the percentage you got from the calculation?
First image is rear tires, perfect. Second image is the front, but it shouldn't matter because the difference is so small and I hope it reads mileage from the rear because RWD.
The Lexus cars do not have the ability to calibrate the ODO.
For the Lexus vehicles, it is already calibrated from the factory (assuming proper size spec tires used as indicated), such that the speedometer will always show at above or at speed and never below. It is not re-programmable/re-calibrated.
Originally Posted by Lexus
Standard indication (Actual speed) / Acceptable range
(speedometer display)
20 mph / 20.0 to 23.0 mph
40 mph / 40.0 to 43.5 mph
60 mph / 60.0 to 64.0 mph
80 mph / 80.0 to 84.5 mph
100 mph / 100.0 to 105.0 mph
120 mph / 120.0 to 125.5 mph
140 mph / 140.0 to 146.0 mph
160 mph / 160.0 to 166.5 mph
CoreY2K1
Aug 11, 2001 01:39 PM
