Fog Light Bulbs ... What size?
I'm looking to switch my stock fogs a yellow "JDM" style bulb ... My issues is I can't seem to find solid information on what size the bulbs are.
I have the premium package which upgrades the headlights to LED ... Slyvania's website list 2 options for fog lights for the 2015 IS, they don't list the 2016 yet, they list an LED with no replacement options and then an H11 bulb.
Anyone know for sure, without taking the fogs apart to find out, which is the correct bulb size and if it's replaceable?
After doing a little more research I came across these ... Can anyone confirm this is what I need?
http://store.ijdmtoy.com/ProductDeta...uctCode=70-101
Based on page 5 of this document, 2016 Lexus IS Specs they are LED (LED Foglamps) so I'm guessing they're not replaceable... or are they?
Headlights can't be changed however, the fogs lights can be changed. Search on Amazon or Ebay for size H11 yellow jdm bulbs or white led. Depending on what color you are planning to change. In addition, you could always buy yellow vinyl and apply it to the fog lights.
Yellow Jdm Style Fog lights
http://www.amazon.com/Optilux-H71071132-Xenon-Yellow-Halogen/dp/B002E2WMWG/ref=sr_1_1?ie=UTF8&qid=1461477599&sr=8-1&keywords=h11+yellow+fog+light+bulbs
White Led Fog lights
I would install these
The correct fog light bulb is H16 Type 2, make sure it's Type 2 and not Type 1 there's a huge difference. The difference between H11 and H16 is H11 uses 55W and H16 use 19W. The H11 bulb will fit in the housing, but I wouldn't use it because it might be too much power for the stock wiring. Unless you get a LED H11 bulb that have a lower output then it's okay.
http://store.ijdmtoy.com/Genuine-OEM...t-p/70-101.htm
Could I swap my factory bulbs into these housings?
Thanks for the help!
2Phast
Nov 11, 2014 12:05 AM
XenonDepot
Club Lexus Vendor Marketplace
Aug 27, 2014 01:01 PM
