Random exhaust backfire/pop
I have a 2016 is350. I just took off my is250 exhaust and installed it onto the 350. It is an invidia axelback paired with a tsudo midpipe. Since I have made the switch I have noticed several times after braking and coming to a complete stop within a couple seconds the exhaust "pops" usually 1 time and it is fairly loud. This did not happen on the 250. What is concerning to me is that it doesn't sound like normal exhaust popping/gurgling when slowing down or downshifting it is more of a sudden loud single pop after coming to a stop. Anyone have any idea what this is? Or if this is considered normal? Also why it would happen on the 350 but not the 250?
Thanks
Thanks
Backfires are from unburnt fuel in the exhaust igniting off hot exhaust gas. This happens generally from removing a catalytic converter, which is used to get rid of those hydrocarbons still left in the exhaust gas. The only way a simple muffler delete should allow this to happen, is due to decreased back pressure that lets the exhaust gas pass through the cats fast enough that the catalyst doesn't finish it's job and let's some hydrocarbon pass through.
It always happens most on deceleration because when you let off the throttle the spark plugs stop firing. So you have a lot more unburnt fuel that was already in the cylinders being pushed into the exhaust instead of being ignited by the plugs.
abenjack (02-23-17)
