Mildew smell from AC - less than 4k miles
Old 05-11-15, 07:17 PM
gennacide
gennacide's Avatar
Default Mildew smell from AC - less than 4k miles
When I turn on my car I get a horrible mildew smell from my AC
There's only 3500 miles on it.
It's garaged every night.
Any suggestions?
Has anyone else had this problem?
Old 05-11-15, 07:37 PM
dojoman
dojoman's Avatar
When you shut off engine is the A/C in recycle air circulation mode? It will cause condensation inside compressor and that's what you're smelling. You should switch to fresh air mode before turning off engine or turn off A/C completely. My car is almost 2 yrs old no mildew smell.
Old 05-12-15, 07:07 AM
Dalva
Dalva's Avatar
Default A/C Smell
Had the same problem with my BMW; condensation is the reason for this "Dirty Socks" smell, the origin of this smell is mold growing on your ac evaporator.
If I may suggest, see your dealer to have this problem fixed, they should know what to do; it was quite a job in my BMW but don't know about Lexus.
Old 05-12-15, 07:33 AM
Noeh
Noeh's Avatar
Ask the dealership for the AC evaporator cleaning service, ~$100.
Old 05-12-15, 08:05 AM
krazykrnbo
krazykrnbo's Avatar
The LS430 always had this problem. Before You get to your destination, switch to fresh air mode. This has helped a lot. Keeps the vents open and sir flowing through to dry up any condensation
Old 05-12-15, 10:42 AM
Machine13
Machine13's Avatar
I have this problem too. I removed the air filter from the glovebox, turned the A/C on high, and sprayed a nice dose of Lysol disinfectant into the A/C. Also sprayed more Lysol on the air filter. Did this a few times over a week or so and the smell is greatly reduced.
I didn't know that putting the A/C on fresh air mode will help it vent. That's good advice. I'm going to start doing that.
Old 05-12-15, 12:13 PM
Fsportlex
Fsportlex's Avatar
The smell is due to the water build up that is happening. Upon return home shut your ac off a mile or so before so it has time to rid the water from the system. I have always done this and never had a smell. Mildew can build up because of not doing so.
Old 05-13-15, 08:11 AM
gennacide
gennacide's Avatar
thanks everyone!
TWillz
LX - 3rd Gen (2008-2021)
12-15-22 05:48 AM
oanda
10-04-08 12:25 AM
dcook26
06-25-08 08:53 PM
GSsnarl
07-30-05 02:41 AM
Quick Reply: Mildew smell from AC - less than 4k miles
