Aftermarket Wheel Showcase - 3ISx Exclusive
#1471
Hopefully, not around the windows. (with the red)... remember KISS. If anything, black out the chrome around the windows, and red the emblems. And maybe even the side chrome pieces on the grill. But I think just the emblems would turn out awesome.
#1473
Did just put new exhaust on her though so may be a little while to rebuild some funds.
#1474
Looked too good to not snap some pix XD
RAYS57ANA
19x8.5/9.5 +36/41
MICHELLINP4S 235/265
Lowered a lil over an inch with GREDDYXKW coilovers
The following 2 users liked this post by l33ks:
beezmarkee (01-17-19),
Slplknight (10-14-18)
#1475
Sorry if wrong thread, just made sense considering the expertise here.
I just got a 2014 Lexus IS250 FSport2, currently on 18 inches for summer but wanting to downsize to 17 inches for winter.
I live in Canada and where I live, winter tires are mandatory. I found a set of winter tires and RWC wheels and wanted to make sure that it'll fit and that the calipers would clear.
I’m buying used to save on costs for right now. Owner says he had a 2014 Lexus IS250 as well, but not FSport.
Wheels are RWC TO80
Bolt pattern is 5x114.3
Centerbore 60.1mm
Offset is 35mm
I found online on https://www.wheel-size.com/size/lexus/is/2014/ that the offset should be 45mm, so that's what I am worried the most.
Can someone please advise? Will this fit?
Wheels are RWC TO80
Centerbore 60.1mm
Offset is 35mm
#1476
Received 1,733 Likes
Wheels are RWC TO80
Centerbore 60.1mm
Offset is 35mm
Wheels are RWC TO80
Centerbore 60.1mm
Offset is 35mm
As you can see from my signature, I have the same model as you.
The 17 inch wheels should be 7.5 inches wide. With the 35 offset they will fit just fine and clear the brakes.
I used to use 16 inch wheels in the winter until I upgraded the front brakes to the 350 larger calipers. Now I run 17 inch winters.
The 17's will fit just fine on your car.
#1477
Welcome to the forum.
Thanks for your input Sasnuke. Highly appreciated! I will get those wheels and tires then!
#1478
Could anyone comment on how a square set up of 18x9.5+35 would look/fit on a lowered car? Any pics as examples? I'm looking for Work Kiwami's and there are so many in my area for sale but they are all 9.5 +35 all around. I know the cookie cutter plug and play set up is 8.5+35 front and 9.5+35 rear. Wondering how the extra 12mm poke from a 9.5 in the front is going to affect everything. Thanks in advance.
#1479
#1480
#1481
I'd like this set-up at stock height, but I'm worried about rubbing and/or poke.
#1484
I have the exact setup only my offsets are +32f +42r on my AWD. With downs my camber in the rear is at the outer limits of the factory settings. I have never rubbed,but I rarely have any back seat passengers. Also consider tire manufacturers. Some have a more rounded shoulder vs a more squared shoulder. You shouldn’t rub at stock height.
VisualEcho (11-02-18)
#1485
