Aftermarket Wheel Showcase - 3ISx Exclusive
#1486
My goal is the standard 19 x 8.5 +35 front with 235/35, and 19 x 10 +40 in the rear with 275/30...at stock height...with no rub. In theory, with the tire I'm choosing, it should work just fine, but only because the wider wheel stretches the tire a bit, making the shoulder more round. I know for sure it'll work with the 265/35, but I like the wider tire.
#1488
#1489
VisualEcho (12-03-18)
#1490
Received 1,738 Likes
It's that time of year...
Bring on the snow. In case anyone is wondering, the winter rims are 2IS 17" wheels powdercoated black with eBay centercaps.
#1492
#1493
wheels are about to be delivered, so need to order tires
went with these sizes and offsets
19*8.5 +38 225/35 or a 235/35 front?
19*9.5 +38 255/30 or a 265/30 rear?
I'm currently lowered with BC coilovers and will be installing SBC camber arms when I put the wheels on
#1494
Most guys go with 235/35 for the front, and 265/30 for the rear, but it depends on how stretched you want your tires to look. I don't think, being lowered and having camber adjustment, you'll have issues with any size you've listed.
#1495
The set up i want to go on my is350 awd is:
18x9.5 +30 with 225/40/18
18x10 +38 with 255/35/18
on rsr downs or superdowns
#1496
Looking into a similar set up! if you were to run 225/40 tires in the front would you still rub with 18x9.5 +30? Also curious to know your rim and tire specs at the back.. any rubbing in the back?
#1498
Former Sponsor
18x9 +32
18x9.5 +40
#1500
The front is hard to say because with the +38 offset it really comes down to rim design if it will clear at this point.
The rear is gonna stick out past the fender a little. It might tuck in enough when the suspension compresses and clear the fender, but it's gonna be close.
