Will my wheel fitment rub?
Old 06-29-14, 11:26 AM
LEXUS1904
LEXUS1904's Avatar
Default Will my wheel fitment rub?
Planning on getting aftermarket rims for my car. My supension will NOT be stock, I'll be sitting on RSR DOWN SPRINGS. I would like my setup to be 19x9.5 (+22 off set) in the front with 225/35/19 stretched tires and 19x10.5 (+22 off set) in the rear with 245/35/19 stretched tires. Will i rub? what do you guys think? thanks for the advice in advance!
Old 06-29-14, 12:51 PM
TheShaddix
TheShaddix's Avatar
This will not only rub but the rims will be hitting your fenders in the rear. +22 is really out there... The only way you can run this is if you go with some coilovers (J5) with really stiff springs (14/12k) and do a bit of fender work front and rear (flatten the front fender lip, etc, and pull the rear a bit). The tire will certainly clear in the back as it will be stretched to crap, but the lip of the rim will go directly into the fender edge and that will not be pleasant... So that's why you need springs stiff enough to limit the travel.
Old 06-29-14, 01:42 PM
LEXUS1904
LEXUS1904's Avatar
Damn, I was hoping I was able to run this with down springs and no fender work... I ran 20x9 +32 in the front with 245/30/20 tires and 20x10.5 +45 in the rear with 285/25/20 tires with little rubbing. I was guessing the offset is low then +22 so I would be able to run this with no problem. I figured I would more worried about the front than the rear because of the extra .5 inch vs. 20x9s.
Old 06-29-14, 02:36 PM
Jaydemm
Jaydemm's Avatar
I have 19x9.5+22 all around wither RSR Super Down springs and my rears rub a tad bit after alignment. Like Shaddix said, you'll need something stiffer and some fender work for you no to rub. I've seen multple people the specs you want just with a higher offset.
Old 06-29-14, 02:37 PM
bucanero
bucanero's Avatar
+22 is a bit too aggressive. You could always just wait until someone makes a wide body kit
Old 06-29-14, 02:42 PM
LEXUS1904
LEXUS1904's Avatar
Did you have some fender work done?
Old 06-29-14, 03:22 PM
Jaydemm
Jaydemm's Avatar
Fronts are rolled pulled and fender liner is cut. Tabs were shaved. Rear only had the fender liner cut and tabs shaved. I wanted them to be rolled and pulled but because of how the fender is, it would look mad deformed.
Old 06-29-14, 03:58 PM
LEXUS1904
LEXUS1904's Avatar
Your setup is almost what my specs are going to be except the I'm going to run 19x10.5 in the rear. Do you think that'll make a difference? I'm just trying to picture how much of my wheels are going to poke out. I ran 20x10.5 +45 in the rear and that worked out fine. But then again it was on stock suspension and my rear rear tire size was 285/25/20..
jt321
IS F (2008-2014)
20
07-25-17 08:35 AM
sethISF
IS F (2008-2014)
25
09-20-13 05:30 PM
lex bubba
Suspension and Brakes
07-11-11 06:41 AM
IndySC300
03-04-11 10:45 AM
jnguyen87
08-29-09 09:00 PM
Quick Reply: Will my wheel fitment rub?
