Rear view camera is not straight
Old May 11, 2014 | 05:14 PM
Dark9t316's Avatar
Dark9t316
When I use the rear view camera lines to park, I'm always parking crooked, which leads me to believe that the camera is actually not installed straight. Does anyone else have this problem? Also is this something I should complain to the dealership?
Old May 12, 2014 | 06:16 AM
Mr_VFS1's Avatar
Mr_VFS1
I was thinking the same thing. I back in a lot and I am always crooked no matter how many times I adjust myself. I never mentioned it or anything but I might construct a test to figure out if it really is crooked or not. Probably will just draw lines in the street and measure things like that. I'll let you know how that turns out.
Old May 12, 2014 | 06:40 AM
JDR76's Avatar
JDR76
Interesting. Maybe it can be aligned/adjusted?
Mine has been dead-on straight when using the lines for backing into a parking spot.
Old May 12, 2014 | 08:40 AM
dojoman's Avatar
dojoman
Maybe it's not the camera's fault? I don't think the lines on the parking lot are painted straight either. Sometime I would have it straight on one side but the other is not.
Old May 12, 2014 | 09:08 AM
Slust's Avatar
Slust
I look over the shoulder to park and just use the camera to see how close I am to the object behind me. Though I have tried just using the camera just to see what it is like.
The camera has been so accurate that many of my passengers have noticed and made comments they wish they had mine. So maybe yours is crooked? Since it's on the trunk lid it's possible it may have gotten loose from constant use of the trunk? Guessing here, really don't know.
Old May 12, 2014 | 09:58 AM
Dark9t316's Avatar
Dark9t316
I have been using the horizontal line to line up with a curb at the end of my car as I back up into a space to park. If I let the line stick (angle) up more on the right side, then I park straight.
RA40
Mar 4, 2017 03:54 PM
Gordonrx
Nov 14, 2015 08:03 PM
HSLexster
HS 250h Model (2010-2012)
Feb 7, 2015 01:22 PM
doki
Mar 3, 2009 02:22 PM
Lex21
Aug 23, 2007 07:34 PM
