Magnaflow exhaust
Old Mar 6, 2014 | 09:16 AM
  #76
Stickyiqqy's Avatar
Stickyiqqy
Love the video. Can't wait to get enough money to purchase, also will be purchasing the invidia mid-pipe & ppe headers. Going to be one sweet exhaust system.
Old May 2, 2014 | 08:46 PM
  #77
jaluco559's Avatar
jaluco559
Originally Posted by Kwik8276
So I got my exhaust put in today and I'm loving it , they did a custom job from the cat all the way to the tips ;-) they deleted the resonators and replaced them with magnaflow mufflers and then stainless steel 2.25 piping all the way thru and put 4 inch tips !!
Attachment 315130
This a pic of the mufflers where the resonators were
Attachment 315131
Hey bro , I Love your ride and that sick exhaust setup.. I have a 2008 is250 Base Model nothing special just some clean wheels, along with Hotchikis Lowering Springs and tinted windows and K&N drop in air filter but I over seen your setup with these magnaflows and now im all lit up on doing this mod to my whip.. What part number are your mufflers..?? Do you think your setup will sound just as good as your ride..??
Old May 2, 2014 | 09:12 PM
  #78
jaluco559's Avatar
jaluco559
Originally Posted by Randre19
Found them on the magnaflow website like you said but there are three 4inch round mufflers offered. You know which one is the correct one they used on your car? They are all the same 4 inch diameter but the overall length is different for each. The have 20", 24", and 28".
Greetings Randre, Hey bud did you ever figure out what the overall length was to the mufflers that were placed in this homies ride or the part number..? Did he ever get back to you and the info..??
Old May 2, 2014 | 10:19 PM
  #79
flowrider's Avatar
flowrider
Veteran: Air Force
My setup has no drone either and those are not resonators , those are the circular magnaflow mufflers that he placed where the resonators were
I'm sorry, but those are are resonators. I have them on my PPE Exhaust system.
Lou
Old May 3, 2014 | 02:18 PM
  #80
Randre19's Avatar
Randre19
He never got back to me with the correct information. Sorry man
Old May 6, 2014 | 04:19 PM
  #81
Kwik8276's Avatar
Kwik8276
Lou
Sorry Lou but those are universal magnaflow mufflers, you can see them in the website, they do look like them and I even asked the shop. .
Old May 9, 2014 | 06:46 PM
  #82
jaluco559's Avatar
jaluco559
Compa I'm here and waiting for your muffler part numbers if you have them please hook me up carnal..?? I'd like my ride to purrr like yours does.. Lol
Old May 14, 2014 | 10:25 AM
  #83
Kwik8276's Avatar
Kwik8276
Hey carnal , I went to the shop and he gave me the info on the mufflers , they are called magnapacks, and the part number was #10416, like I said sorry for the delay and they installed those where my resonators were and did the piping from there to the pipes , the pipes were 2.25
Old May 14, 2014 | 11:00 AM
  #84
Joe Z's Avatar
Joe Z
Lightbulb FYI for ALL
A resonator is a round muffler in essence.. When used mid-stream to assist in exhaust noise reduction..
Simple descriptions below.. But I have seen plenty of Resonators used in place of a Mufflers location.
Resonator in Automobiles
The exhaust pipes in automobile exhaust systems are designed as acoustic resonators that work with the muffler to reduce noise, by making sound waves "cancel each other out"[1]. The "exhaust note" is an important feature for many vehicle owners, so both the original manufacturers and the after-market suppliers use the resonator to enhance the sound. In 'tuned exhaust' systems designed for performance, the resonance of the exhaust pipes can also be used to 'suck' the combustion products out of the combustion chamber at a particular engine speed or range of speeds
Muffler in Automobiles
Mufflers are installed within the exhaust system of most internal combustion engines, although the muffler is not designed to serve any primary exhaust function. The muffler is engineered as an acoustic soundproofing device designed to reduce the loudness of the sound pressure created by the engine by way of Acoustic quieting. The majority of the sound pressure produced by the engine is emanated out of the vehicle using the same piping used by the silent exhaust gases absorbed by a series of passages and chambers lined with roving fiberglass insulation and/or resonating chambers harmonically tuned to cause destructive interference wherein opposite sound waves cancel each other out. An unavoidable side effect of muffler use is an increase of back pressure which decreases engine efficiency. This is because the engine exhaust must share the same complex exit pathway built inside the muffler as the sound pressure that the muffler is designed to mitigate.
Some vehicle owners remove or install an aftermarket muffler when engine tuning in order to increase power output or reduce fuel consumption because of economic or environmental concerns, recreational pursuits such as motorsport and hypermiling and/or for personal aesthetic acoustical preferences. Although the legality of altering a motor vehicle's OEM exhaust system varies by jurisdiction, in most developed parts of the world, modification of a vehicle's exhaust system is usually highly regulated if not strictly prohibited.
~ Joe Z
Old May 14, 2014 | 11:48 AM
  #85
iRyan's Avatar
iRyan
sound nice i might try
Old May 15, 2014 | 09:13 PM
  #86
LexFather
Guest
Posts: n/a
I've worked with Magnaflow and everyone I know with them has been happy. Usually a nice throatier sound with larger tips.
Old May 15, 2014 | 09:24 PM
  #87
Kwik8276's Avatar
Kwik8276
Couldn't agree more:-)
Old May 26, 2014 | 04:23 PM
  #88
jaluco559's Avatar
jaluco559
Hey bro, whats up! Hope you're having a gr8 weekend anyhow thanks for the info.. Greatly Appreciated.. Anyhow I was wondering if you could post some pics from the back of those Magnapacks all the way out to your tips if it ain't to much trouble for you.. Osea a lo que se ve the pipes run straight back after that with those 4" tips is that how it is..? Are your tips smooth at the end or the rounded oval ends rolled inward you know what I mean..??
Old May 26, 2014 | 05:32 PM
  #89
Kwik8276's Avatar
Kwik8276
Hey bro, it's no problem, I thought I put all the pics on the forum of how the piping was, try going back to the beginning of this post to see if that helps, if not private message me your number and see if i could be more help, and the tips are 4 inch tips with rounded edges, I'll take pics and show you what I mean
Old May 27, 2014 | 12:30 AM
  #90
Boomin's Avatar
Boomin
I start hearing some drone after 65 mph and 70 mph but very little
Now you're scaring me.. I average 80mph for about 2 hours each way, definite drone??
