Obsidian Concerns - Opti Coat?
Old Nov 27, 2013 | 11:36 PM
SonyHome's Avatar
SonyHome
Originally Posted by zmcgovern4
Paint coatings, such as Opti-Coat, are an extremely wise investment.
Opti-Coat (and other premium paint coatings) will have a higher surface hardness than most factory clear coat finishes. For this reason, as you had implied, they have the ability to reduce light swirls and marring that often result from washing and drying.
Obsidian is a very soft clear coat. As you might know, clear coat hardness varies greatly from one manufacturer to the next, and often even between different colors in the same manufacturer. For instance, my smokey granite mica is much more tolerable than obsidian.
With that being said, NOTHING will permanently protect your vehicle from swirls and marring forever. The fact of the matter is that if you are touching your vehicle, you risk the chance of damaging it. All you can do is use proper technique and minimize the amount of swirls/defects so that future polishing is much easier and less evasive.
Swirls and scratches are removed via machine polishing which actually removes a fine layer of paint. For this reason, you want to minimize the severity of the surface defects so that less material needs to be removed to refine the finish.
Besides surface hardness, premium coatings such as Opti-Coat Pro and CQuartz Finest are crucial to maintaining your paint. Some other benefits that these products provide are:
A thick, durable layer of protection: First, let me clarify that wax (despite the common belief) is used for protection, not to make your car super shiny! Wax will wear away in as little as a couple of weeks depending on your environment and the condition in which you keep your car. These semi-permanent coatings will offer years of protection.
Wax is also very thin, making it very easy for environmental contaminates such as bird droppings, acid rain, bug splatter to penetrate the layer of wax and reach your paint. Bird bombs and bug guts, for instance, are quite acidic. They can and will cause permanent damage that requires repainting. High quality paint coatings are thick enough that these contaminates will be stopped before they can reach your factory finish. This will help to preserve your paint much better than traditional forms of protection (ie wax or sealant).
Also, due to the added thickness of a premium coating, any light surface marring will reside in the coating and NOT in the clear coat. This means the next time the vehicle is polished, the coating will be removed and not the clear coat (or at least much less paint).
*Remember, these coatings are a sacrificial layer of protection... they are meant to take the abuse so that your paint does not have to! Note: they are not meant to protect from rock chips like a clear bra, they simply provide long lasting, durable protection against environmental contamination and damage.
Ease of Maintenance: Because these coatings resist dirt and debris MUCH better than traditional protection, routine washes are much easier. No scrubbing is required and dirt easily wipes away. This makes it safer to wash your car and reduces the chance of introducing wash induced marring or swirls.
Gloss & Shine: Some of these coatings, CQuartz Finest in particular, offer ridiculous gloss. Your car will have that "just detailed" after you wash it look for years, not weeks.
^My car 1 year after it was last polished and coated... still looks pretty good, huh
I could keep going, however I have an entire article on this subject that will be published on the Detailed Image Ask-A-Pro Blog in the near future, so keep an eye out.
More info on CQuartz Finest here & here.
More info on Opti-Coat Pro here.
OP: Your location simply states "midwest"... if you'd like to provide more info as to what that means I would be more than happy to put you in touch with a respected professional in your area who is authorized to install a pro coating like Opti-Coat Pro or CQuartz Finest.
-Zach
Hey Zach,
Your car looks amazing!
I'm interested in knowing a professional in my area that install pro coating like CQuartz Finest /Opti-Coat Pro. I'm located in Minneapolis, MN in northern suburbs but wouldn't mind anyone in the Twin City area.
Also I'm looking to get Xpel or Suntek PPF and I noticed you suggested not to CQuartz Finest /Opti-Coat before PPF? Why is that? I would have thought you would do the CQuartz Finest /Opti-Coat on the whole car first.
Thank you for your input.
Old Nov 30, 2013 | 03:07 PM
zmcgovern4's Avatar
zmcgovern4
Auto Detailing Master
Originally Posted by SonyHome
Hey Zach,
I'll PM you regarding a specific professional in your area.
Professional installers for cquartz finest can be found here: http://cqfinest.com/where-to-buy.html
Professional installers for opti-coat pro can be found here: http://opti-coat.net/approved-dealers.php
The reason you do not want to have a PPF installed on top of a coating is because you want the PPF installed directly on top of the paint. If you install it on top of a coating like Opti-Coat or CQuartz Finest, there is a chance that the PPF could have issues if the coating product starts to diminish after many years... while I have not personally heard of this issue happening to anyone, it is a risk that can easily be avoided by simply installing PPF without a coating beneath it.
Hope that helps!
-Zach
sharmila19
57
Jul 4, 2018 08:11 AM
Nilism
Aug 26, 2012 06:34 PM
eknine9
Automotive Care & Detailing
May 23, 2012 03:21 PM
rselby
Jun 16, 2010 10:53 PM
slammedgs
Feb 7, 2002 08:44 AM
