20 Inch Wheels and Offsets
With the 21+ IS. Lowered on Eibach ProKits. I will be going 20x9 in the front and 20x10 in the rear.
Does anyone know the lowest offset I can go for the front and rear? I want to achieve the Flush fitment (the fender and lip of wheel in line all the way down.) I wouldn’t mind a couple of MMs of poke.I will be running a slight stretch tire if needed.
Thanks in advance!
Thanks in advance!
I would say +30 up front and +40 out back, i am running 20x9 +38 offset and 20x10.5 +45 out back and drop on RS-R spring my front is shunk in a bit, may need maybe 10mm spacer to **** flush to the fender, but out back is poke about 5mm out which i like.
Oh ok, sounds good!! Got any pics?
Depends on what wheel, we can get you setup.
-Josh
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
CamRen
Wheels, Tires & Brakes Forum
Jan 14, 2003 09:36 PM
