Unusually loud engine tapping | 2GR-FKS
Old Mar 31, 2024 | 01:15 PM
xbubby's Avatar
xbubby
6th Gear
Default Unusually loud engine tapping | 2GR-FKS
Hello all, to preface I have a 2018 IS350 AWD, ~94K mi. Keep up with all maintenance. The 2GR-FKS is making an unusually loud tapping noise. I know they usually do and I’ve gotten used to it, but this is noticeably louder. I can attach a video if needed but anyone else experience this?
I have to be honest, it only started doing this after a trip to TN from OH. I also did tail of the dragon and pushed it. I just really hope this isn’t a cam issue.
Old Apr 1, 2024 | 03:56 PM
EdgarLex's Avatar
EdgarLex
There is a very high chance that your car is just fine. All 2GR FKS make weird noises lol.
If your engine sounds like this from my vid ->
it is perfectly fine. There are several TSBs out for a noisy vacuum pump. The high pressure fuel injectors also make a ruckus and finally these are just loud engines. If it doesn't sound like a sewing machine it ain't working good :P
Old Apr 9, 2024 | 09:24 PM
PhilD83's Avatar
PhilD83
10th Gear
the 2gr f(xx) engines all dp that. Run some intake cleaner spray and a can of engine flush before your next oil change. Add a can of ceratec or similar to that oil. Should fix the issue
Old Apr 15, 2024 | 08:05 PM
richieca's Avatar
richieca
Its normal. What sounds like lifter tap is the port injectors. That V6 has both direct injection is quieter so when it cycles to port its louder.
AZ7
Jan 11, 2024 04:55 AM
ncatona
Jul 18, 2023 09:30 PM
jblitz
Nov 19, 2021 09:42 AM
anniversar
Apr 20, 2015 09:54 PM
scfocus
Jul 29, 2008 11:51 AM
