TPMS reprogramming
Old Apr 17, 2023 | 08:50 AM
Dalvas's Avatar
Dalvas
2nd gear
Default TPMS reprogramming
Hello, Can anybody tell me if the onboard computer needs to be reprogrammed on every tyre change ? My summer and winter tires are mounted on rims and TPMS valves, my dealer charges 50$ for reprogramming the computer so it can recognize those TMPS valves. Am I being robbed ? Thanks
Old Apr 17, 2023 | 10:34 AM
arentz07's Avatar
arentz07
You are not being robbed. You would have two separate sets of sensors, and the car has to know which sensors to communicate with. Some manufacturers, like Porsche, have automated this process, to where it can be done without special equipment or procedures, but with Lexus, there are steps involved in pairing the sensors to your vehicle. The alternative is to simply run without sensors during winter.
Old Apr 17, 2023 | 11:19 AM
Dalvas's Avatar
Dalvas
2nd gear
Thumbs up
Thank you for a very clear answer.
Old Apr 17, 2023 | 01:53 PM
LaZeR's Avatar
LaZeR
Question
... TPMS valves, my dealer charges 50$ for reprogramming the computer...
... You would have two separate sets of sensors, and the car has to know which sensors to communicate with. ... with Lexus, there are steps involved in pairing the sensors to your vehicle....
Does this HAVE to be done by a Lexus dealership/Service, or can any reputable shop/mechanic do it?
Old Apr 17, 2023 | 04:28 PM
arentz07's Avatar
arentz07
I believe it is possible for any shop or technician provided they know how to do it.
This seems good:
Old Apr 17, 2023 | 04:31 PM
wsvc206's Avatar
wsvc206
Discount Tire does it for free
Old Apr 17, 2023 | 09:12 PM
lexo98's Avatar
lexo98
I don’t think anyone really does it for free, but can if you ask nicely. I would think that if they were charging you to swap the wheels they would just include it.
Old Apr 17, 2023 | 11:18 PM
Ethanol's Avatar
Ethanol
On my IS200t there's a button under the dash (adjacent to the PCS deactivation button) which need to be pressed three times in order to swap between winter and summer TPM sensor sets. The vehicle is able to store two sets of sensors, no need to reprogram them every time.
Old Apr 18, 2023 | 06:54 AM
kj07xk's Avatar
kj07xk
You can buy your own programming tool, I did. It pays for itself after a couple of seasons.
Old Apr 19, 2023 | 09:04 PM
athanato's Avatar
athanato
2nd gen IS stores two sets where 3rd gen IS only stores one set of TPMS sensor IDs. Also 2nd gen and 3rd gen use different frequencies.
Get compatible TPMS sensors that allow for cloning the IDs of your original set to avoid re-programming your car plus the required scanners/programmer. There is a thread that cover this and you can find the Autel TPMS units for $150 on Amazon and they also have the sensors which usually range between $35-$50 each.
Amazon Amazon
Amazon Amazon
Old Apr 19, 2023 | 09:31 PM
lexo98's Avatar
lexo98
https://www.amazon.com/Autel-TS401-A.../dp/B00AERMVYC
https://www.amazon.com/Autel-MX-Sens.../dp/B089FYJ9QR
Pretty sure the frequency is the same but the newer Gen Lexus’s show actual wheel position and that requires a different type of sensor.
Old Apr 20, 2023 | 03:13 PM
Lex_Giorgio's Avatar
Lex_Giorgio
If you're near Vaudreuil, I can program it for you.
lenbabin
RX - 4th Gen (2016-2022)
38
Sep 2, 2024 04:39 PM
j1ffrey
NX - 1st Gen (2015-2021)
Sep 8, 2022 01:08 AM
xcanuk
Apr 16, 2022 09:08 PM
spender
LX - 3rd Gen (2008-2021)
Dec 15, 2014 09:37 PM
