P0300 Multiple Cylinder Misfire Detected
Old Aug 14, 2022 | 06:44 PM
SerigoR's Avatar
SerigoR
Default P0300 Multiple Cylinder Misfire Detected
Hello, i recently replaced my starter because car was not turning over. After completing the job
I went for a test drive and i noticed that the acceleration was sluggish and car would shake when shifting to the next gear. I checked the codes and got P0300.
Old Aug 15, 2022 | 01:14 PM
2013FSport's Avatar
2013FSport
Double check your work. If it was fine before the repair, it sounds like you might have created a vacuum leak as that error says random misfire among most if not all of the six cylinders.
So whatever it is, fuel, spark, or air, its happening to several cylinders. Hopefully it's something obvious.
Old Aug 15, 2022 | 01:24 PM
SerigoR's Avatar
SerigoR
Problem seem to fix on its own in the morning. thank you
FRSTDJ
Nov 19, 2018 01:04 PM
Jlacck
Oct 9, 2017 11:22 AM
CJLennon
Oct 6, 2011 12:00 AM
gsCrazy
Jan 7, 2008 09:37 PM
